RPO code G80 on iroc
Car: 1992 Camaro RS 25th Anni.
Engine: 5.0l TBI
Transmission: 700R4 Automatic
Axle/Gears: 3.73 Gov lock
I just bought an '87 iroc parts car and one of the RPO codes is G80. The decoder calls this "G80: Axle positraction limited slip"
How can an axle be both Ls and posi?
How hard would it be to swap this rear into my 91 RS with a 3.1l v6 and 3.23s?
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: RPO code G80 on iroc
Posi is the GM name for a LS differential.
All third gen diffs will interchange into another third gen. The only issue may be brake lines or park brake cables as they changed slightly over the years.
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Positraction and limited slip are two different names for the same thing.
hectre13
Dec 11, 2023 08:14 AM
mustangman65_79
Aug 11, 2015 03:17 PM
