4th gen pedals
Old Sep 30, 2007 | 01:08 PM
spina74's Avatar
Car: 01 Trans Am Ws6, 92 Camaro Rs
Engine: 6.0, 305
Transmission: T56,700R4
Axle/Gears: 3.90 9", 2.73 10 bolt
4th gen pedals
I have the t56 in my car and i was having some issues such as my pressure plate squealing when i push the clutch down too far, and also my clutch doesn't engage until my pedal is almost all the way up. I looked around on here and found out it is the 3rd gen pedals doing it because they have more movement then the 4th gen pedals do. Now if I swap to the 4th gen pedals which I plan on doing do i have to undo my clutch line, then rebleed them so my master cyl can be adjusted to the pedal or after installation do i just pump the clutch pedal to re-adjust them?
Old Sep 30, 2007 | 05:11 PM
Re: 4th gen pedals
No bleeding, pumping, re-adjusting, or any of that required; just unhook and rehook.
19irocz85
Aug 30, 2015 10:03 PM
cam-mike
Aug 24, 2015 07:23 AM
redmaroz
Aug 16, 2015 11:40 PM
