Please Help 700r4
Old Oct 2, 2007 | 10:28 AM
brnrubr4ever's Avatar
Please Help 700r4
I rebuilt my 700 about 2 months back using one of probuilts prostreet kit with the transgo reprograming kit. I finally got everything buttoned up and tried testing it this past weekend, and I have NO gears 1st, 2nd ,3rd, 4th and reverse are not there until about 4500 rpm with the wheels off the ground and its still very weak. Im thinking its line pressure but im not sure since this is the first trans Ive every built. Any ideas,
Thanks Ricky
Old Oct 2, 2007 | 10:51 AM
Burnout91's Avatar
Car: '91 Z28 L98 G92
Engine: Modded L98
Transmission: Modded 700R4
Axle/Gears: Modded 10-Bolt
Re: Please Help 700r4
Call Dana @ Pro Built.
Bill
Old Oct 2, 2007 | 12:29 PM
84 z28's Avatar
Car: 1984 z28
Engine: 355
Axle/Gears: Moser 9" 4.11
You have enough fluid in it ???
Old Oct 2, 2007 | 12:37 PM
Yea according to the dipstick I do. Do you think my tranny cooler and lines might be affecting pressure?
Old Oct 2, 2007 | 04:54 PM
87zjeff's Avatar
Axle/Gears: '01 3.42 10 bolt
are you 100% positive you got the boost valves in the pump all the way? the snap ring can be a tricky b#*ch......
Old Oct 2, 2007 | 05:43 PM
Mikz86TA's Avatar
Car: '86 Trans Am and '03 S-10
Engine: 355ci and 4.3l
Transmission: 700R4 and NV3500
Axle/Gears: 7.625/3.42 Auburn and 8.5/3.08 Gov-
1st. What did you remove and or replace? 2nd these other post are all liable points and you should check them too. A pressure gague would be helpful too.
Old Oct 2, 2007 | 06:31 PM
Pro Built Automatics's Avatar
Call me. 909 7951876 I will be around most of the evening, if you miss me leave a message and phone number, and I will call you as soon as I return. Dana
Old Oct 2, 2007 | 07:35 PM
Sorry Dana just got home and checked this, I'll give you a call tomorrow, I did get the boost valve in all the way. Checked a couple of things and it looks like my TV cable might be binding. So I ordered a couple of brackets for it today do you think this could be it? I'll see if I can find a gauge tomorrow, 250 psi good? and can I get a t fitting and hook it up to my trans cooler line?
Thanks guy really appreciate it
Ricky
loud91rs
Oct 5, 2015 10:05 PM
92projectcamaro
Sep 29, 2015 07:07 PM
IROC ZELLER
Sep 29, 2015 03:00 PM
indygene
Sep 26, 2015 11:21 AM
6998poncho
Sep 25, 2015 02:56 PM
