700r4, 1-2 shift at 2500-3000 rpm
Old Oct 3, 2007 | 01:45 PM
tyrvidar's Avatar
Car: 83 Z28, 88 Iroc
Engine: 305 CFI, 350 TPI
Transmission: 700R4, 700R4
I suck when it comes to troubleshooting Transmissions and my knowledge is limited.
This is a stock rebuilt 700r4 transmission I bought and had installed at a transmission shop 6 months, and 4 thousand miles ago. (Take it to the shop have them look at it...) Way ahead of you guys, I will... but first I want a general idea of what might be happening...
The car revs up to about 2500 to 3000 rpm before first shifts to second, after that all my other gears shift fine it seems. The searches for the forums are a bit on the crap side these last couple of weeks...
Another question I have, is it common for stock 700r4 to over rev and not shift correctly (get stuck) when you gun it?
Old Oct 3, 2007 | 02:29 PM
Toehead's Avatar
Car: 1985 Berlinetta
Engine: Megasquirted TPI
Transmission: Transgo 700R4
Re: 700r4, 1-2 shift at 2500-3000 rpm
What throttle position do you test at?
Old Oct 3, 2007 | 02:45 PM
tyrvidar's Avatar
I gun it a little bit to about 40-50% + (my guess) it it will shoot up to 2500-3k sit there for a second then it shifts(Shifts fine, no clunking or anything). If I am cruising around my work area (speed bumps blah blah) I don't open it as much (maybe 20-30% or so) which takes it to about 2k-1750 and shifts fine at that point as well (after it sits there for a second or 2, almost like it is building up pressure?)... Any ideas?
Old Oct 4, 2007 | 11:04 AM
tyrvidar's Avatar
2nd Gear is slipping, dropped it off this morning. Fun stuff
Old Oct 4, 2007 | 12:10 PM
Mikz86TA's Avatar
Car: '86 Trans Am and '03 S-10
Engine: 355ci and 4.3l
Transmission: 700R4 and NV3500
Axle/Gears: 7.625/3.42 Auburn and 8.5/3.08 Gov-
1st I would check for correct TV cable adjustment. But there might be a sticking valve in the VBody.
IROCtometal
Sep 20, 2015 11:08 PM
TheTraut88
Sep 11, 2015 05:16 AM
IROCtometal
Sep 9, 2015 10:01 AM
TheTraut88
Sep 7, 2015 05:22 PM
IROCtometal
Sep 2, 2015 02:01 PM
