performance minded 700r4 rebuild cost
Old Oct 3, 2007 | 02:47 PM
89importeater's Avatar
Car: 89 RS camaro
Engine: 454 swap in progress
Transmission: th400
Axle/Gears: 4.11
about how much you guys think it would cost to rebuild a 700r4 to support 500-600hp/tq? i have been tossing around the idea of getting a th400 for this but i cant seem to find one and if so the prices are so i was just wondering about how much it would cost and what would need to be upgraded in the 700r4 to live happily behind a 500-600hp/tq motor.
Old Oct 3, 2007 | 03:03 PM
84 z28's Avatar
Car: 1984 z28
Engine: 355
Axle/Gears: Moser 9" 4.11
Re: performance minded 700r4 rebuild cost
2000-3000 grand
Old Oct 3, 2007 | 03:48 PM
Burnout91's Avatar
Car: '91 Z28 L98 G92
Engine: Modded L98
Transmission: Modded 700R4
Axle/Gears: Modded 10-Bolt
Between the cost of the ProBuilt street/strip rebuild kit, Edge 9.5" 2600 stall
converter, trans removal, trans kit install and trans installation, I will be (haven't had the installation done yet) in for about $2200.....wait, I have to go....my boss wants to know if I can work this weekend
Bill
Old Oct 3, 2007 | 03:57 PM
Car: 89 RS camaro
Transmission: th400
Axle/Gears: 4.11
well i think in the end the th350 or 400 would still be cheaper, thats alot more than i figured although trans instal and removal wouldnt be needed.
Old Oct 3, 2007 | 07:35 PM
84 z28's Avatar
Car: 1984 z28
Engine: 355
Your better off with a 350 rather than a 400. 350 has less fitment issuues all the way around and also takes less hp to use.
Old Oct 3, 2007 | 10:18 PM
Car: 89 RS camaro
Transmission: th400
Axle/Gears: 4.11
although it may have less fittment issues i am not sure that the th350 would hold up to much better. Plus i was planning on getting a spohn torque arm with th400 crossmember. i was looking through this classifieds thing we get and i just found a short tail shaft th400 for $100. i dont know if i should call the guy tomorrow or not whats is the weak points of the th350 and the th400 and roughly estimated how much would it cost to build each to suit my needs. i just dont know what to do you guys. thanxs for any help
Old Oct 4, 2007 | 12:01 AM
Mikz86TA's Avatar
Car: '86 Trans Am and '03 S-10
Engine: 355ci and 4.3l
Transmission: 700R4 and NV3500
Axle/Gears: 7.625/3.42 Auburn and 8.5/3.08 Gov-
400 weighs more. 350 can be build just as strong for your use
Old Oct 4, 2007 | 07:52 AM
84 z28's Avatar
Car: 1984 z28
Engine: 355
A properly built 350 can take a ton of abuse. If you go the 400 route you need to look in too new drive shaft( you will on the 350 anyway) crossmember,torque arm, and you are limited of headers also.
Old Oct 4, 2007 | 09:38 AM
Car: 89 RS camaro
Transmission: th400
Axle/Gears: 4.11
Yea, i didnt think about headers. thanxs, you probably saved me a biig headache down the road. What is the weak link in the th350? (search is a no go)
Old Oct 4, 2007 | 12:07 PM
Tobias05's Avatar
Car: 1987 Camaro SC, 1999 Z28
Engine: GMPP 350HO, LS1
go probuilt. 3.06 first gear and overdrive are always nice. it costs more, no doubt about it, but why jump backwards in technology. cost will be ofset anyways changing out all the other components to compliment the 350.
probuilt.
Old Oct 4, 2007 | 12:29 PM
84 z28's Avatar
Car: 1984 z28
Engine: 355
Parts for a 350 are cheaper still have to build the crap out of it to handle the horsepower you want.
Old Oct 5, 2007 | 03:14 PM
galvarado's Avatar
Car: 88 Camaro SC
Engine: Aluminum Vortec headed 383 roller
Transmission: ProBuilt 700R4
Axle/Gears: 9 bolt/3.27
I purchased the street/strip rebuild kit from ProBuilt and had a local shop rebuild my original stock 700R4. Parts, converter and labor cost me a little over $1200. But then again, you need it to hold up to more horsepower.
Gene
Old Oct 5, 2007 | 04:32 PM
89formula=happy's Avatar
You could get one already done from summit.
InfinityShade
Feb 21, 2016 01:29 PM
Reddeath210
Oct 6, 2015 08:20 AM
someone972
Aug 30, 2015 12:52 AM
sreZ28
Aug 14, 2015 07:48 PM
TreDeClaw
Aug 14, 2015 06:58 PM
