2.73 to 3.73?
Old Oct 10, 2007 | 09:13 PM
Iroc350ci's Avatar
2.73 to 3.73?
Hey, Ive got a 86 Camaro with the 2.8 in it. ive done basic power adders K&N filters, Royal purple synthetic oils. Flowmaster exhaust , test pipe(not quite sure if it adds power). what i was wondering is I right now have 2.73 gears in it (last owner had no clue what he was buying) i have now a 3 series carrier with 3.73 gears to go with it.. what is my torque increase going to be like after i install new gears. With my current gears.. my car just dogs like no other . i am hoping to accomplish a double edge with my gears.. maybe adding a little pep and take some "pressure" off of my clutch as it seems to shutter when trying to take off in those tight traffic situations.
Just lookin for some feedback and maybe a little info.
Old Oct 11, 2007 | 01:43 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Re: 2.73 to 3.73?
Yea, it'll make it get up and go a lot easier.
If your clutch is chattering you may be due to get your flywheel resurfaced. The gears won't effect that.
Old Oct 11, 2007 | 04:34 PM
Mikz86TA's Avatar
Car: '86 Trans Am and '03 S-10
Engine: 355ci and 4.3l
Transmission: 700R4 and NV3500
Axle/Gears: 7.625/3.42 Auburn and 8.5/3.08 Gov-
Re: 2.73 to 3.73?
Dang. Even GM put steep gears in the V6 cars from the factory. My 305 was a pig with 2.73s originally and I drove my sisters 2.8 with 3.42s also. It too was a pig and needed some gearing help.
Old Oct 11, 2007 | 05:04 PM
jimmy92rs's Avatar
Car: 1992 RS
Engine: 01' LS1
Axle/Gears: 10 bolt auburn pro posi, 4.10 gears
Re: 2.73 to 3.73?
i went from 3.08s to 4.10s, and boy that was a difference.
Old Oct 11, 2007 | 05:59 PM
ryan91rs's Avatar
Car: 1991 RS, 84 El Camino conquista RIP
Engine: 5.0 (for now)
Transmission: 4L60
Axle/Gears: 2.xx torsen limited slip & 3.42 ope
Re: 2.73 to 3.73?
ha ha ya and 3000 rpm going 65. lol. i say 3.73 is streetable and 3.42 for some economy. but what ever, just remember what you are using it for.
also you will have to recalibrate the speedo.
Old Oct 15, 2007 | 08:04 AM
tenpin842's Avatar
Car: 1987 Trans Am
Engine: 5.0L TPI
Axle/Gears: Richmond 3.73
Re: 2.73 to 3.73?
I went from 2:73 to 3:73.....I like it a lot!
Keep us posted once you install them!
Old Oct 15, 2007 | 12:38 PM
Iroc350ci's Avatar
Re: 2.73 to 3.73?
All the parts are here with me.. just now to install em kinda need the car to get to school for right now but who knows maybe ill lay the car up on blocks for a day or 2 and get em done i will keep everyone updated
Old Oct 17, 2007 | 12:56 AM
ownor's Avatar
Car: 84 TA / 89 Formula
Engine: LS1 / L03
Transmission: T56 / 700R4
Axle/Gears: 3.73 / 3.27
Re: 2.73 to 3.73?
yeah that's really sloooow gears for a V6. my 305 tbi formula has the 2.73, plus 245 tires, lol "did i just floor it?"
i already ordered 3.42 gears and hopefully will at some point find a posi carrier for it as well! btw, where do i order the right gears for the VSS?
Old Oct 20, 2007 | 06:06 PM
Iroc350ci's Avatar
Re: 2.73 to 3.73?
Gears are in .. still breakin them in. only thing there is a whirrrring sound when i declerate.. is this a bad sign?
Old Oct 23, 2007 | 10:35 PM
ownor's Avatar
Engine: LS1 / L03
Re: 2.73 to 3.73?
hi,
where did you get your gears from? i read that aftermarket gears like motive can cause strange noises.. not too sure about that though - or maybe you already found out what's wrong? and what do/did you do to break them in?
so btw, can anyone tell me where to get the speed sensor gears?
Old Oct 24, 2007 | 12:50 PM
Iroc350ci's Avatar
Re: 2.73 to 3.73?
Originally Posted by ownor
hi,
i got mine from Jawsgear.com i bought the gears and the install kit cost about 250 or so break in basically involved goin around town at normal speeds for maybe 10 miles per time and then maybe an hour cooldown, time then back in the car again for another 10 miles.. its been less than a week and they are running great.. my car is a hell of alot quicker and i can finaly chirp them tires... 2.73 couldnt even think about breakin em loose
Old Oct 24, 2007 | 01:33 PM
ownor's Avatar
Engine: LS1 / L03
Re: 2.73 to 3.73?
sounds great!
thanks for the break-in description!
i have some more questions: i want to go 3.42 and eaton posi on my formula. i don't exactely know what people consider to be the "carrier". where can i get a 3-series carrier, or do i just need a 3 series posi and everything's fine?
Old Oct 24, 2007 | 01:56 PM
Quasi-Traction's Avatar
Car: 1986 Camaro Berlinetta
Engine: 4 bolt 355ci
Transmission: Borg Warner T-5
Axle/Gears: 3.73 Posi Disc Rear
Re: 2.73 to 3.73?
2.73 to 3.73 was a night and day difference for me.
the only thing that made it suck was getting traction at the track on street tires, I could dump the clutch at 2500 with the 2.73's and chirp and go.
If you got a 2 series carier lying around, you can always buy a ring gear spacer and stick your 3 series gears in it.
Old Oct 24, 2007 | 04:29 PM
ownor's Avatar
Engine: LS1 / L03
Re: 2.73 to 3.73?
is there a difference in durability or performance between my 3.42+3series posi setup with a 3 series carrier or a 2 series carrier with a spacer ring?
thanks
oh and i'm still wondering where you get those speed sensor gears
Old Oct 24, 2007 | 08:21 PM
ryan91rs's Avatar
Transmission: 4L60
Re: 2.73 to 3.73?
well those gears are hard to find and a dealer only part. Also to put the new gears in they or a good tranny shop has to take the tail shaft off and get in there to change it. A big pain in the butt and the major reason i'm not doing it. Then again they make aftermarket controllers that allow you to change how many pulses equal a certain mph. I'm thinking if it's compatible to our older cars (not being OBDI) then that might be the best way. not for certain though. I think i just added more questions. lol!
Old Oct 24, 2007 | 08:48 PM
ryan91rs's Avatar
Transmission: 4L60
Re: 2.73 to 3.73?
I found something! a guy on this form is using a "vss ratio adapter made by Abbott" this allows you to change the pulses that go out and is supposably computable. score! no i might actually do another rear end change then again it kinda sucks!
Old Oct 24, 2007 | 08:53 PM
Iroc350ci's Avatar
Re: 2.73 to 3.73?
I got my carrier on Ebay 200 dollars.. series 3 7.625 carrier just had to trust the fact the guy who was sellin it new what he was doin. i lucked out.. just got that whirring sound wich is one of two things ive read.. my coupler on the mend of my driveshaft isnt tight enough or i dont have the carrier shimmed right inside of the pumpkin.
i forgot to mention lol im only 17 years old.. so this is all new to me .. any advice is awsome
JSDaddy189
Sep 26, 2015 03:50 PM
64Chief
Sep 12, 2015 08:05 AM
whyt86roc
Sep 10, 2015 10:03 PM
john204481
Sep 7, 2015 03:22 PM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
