My 700R4 can shift into gear WITHOUT the key in ignition!
Old Oct 11, 2007 | 02:41 PM
19CAMARO85's Avatar
Car: 1979 Z28 / 1990 RS
Engine: Matching 350 / 305 TBI
Transmission: Built TH350, 3000 Stall / 700r4
Im not sure what does it but i can shift the car into gear with out having the key in the ignition... the car wont start when in gear but it doesn't lock into park when the key is out... i could put the car in gear (neutral) and push it and then put it back in park. Help Me. -Matt
Old Oct 11, 2007 | 03:31 PM
Shift06's Avatar
Car: 1991 Trans Am GTA
Engine: LSX (swapping)
Transmission: 4L60E (swapping)
Axle/Gears: 2.73 Posi 10 Bolt
Re: My 700R4 can shift into gear WITHOUT the key in ignition!
Don't they all?
Old Oct 11, 2007 | 03:35 PM
Burnout91's Avatar
Car: '91 Z28 L98 G92
Engine: Modded L98
Transmission: Modded 700R4
Axle/Gears: Modded 10-Bolt
On my '91 Z28, there is a cable that runs from the ignition switch to the shift lever, that accomplishes locking the shifter in park when the key is turned to the 'lock' position of the ignition switch. When I installed a Dual/Gate shifter, for some reason, the cable would no longer reach the shifter attach point, thus disabling the shift lever lock feature (I can move the shifter without the key in the ignition). Check the cable connection at the ignition switch and at the shifter.
Bill
Old Oct 11, 2007 | 03:37 PM
Thirdgen89GTA's Avatar
Car: 1989 Trans Am GTA
Transmission: M28 T56
There should be a solenoid that locks out the shift button when the key is not in run.
Either the solenoid is dead, not there, or its been disconnected.
________
My car had the solenoid, but the P/N safety switch was bypassed. So I could start my car in any gear. I made that mistake once. Never again. Wired it back up the right way as soon as i figured out why my car started moving when I put the key in crank positon.
Old Oct 11, 2007 | 03:59 PM
kuulkatdadieo's Avatar
Car: 1989 Pontiac GTA
Engine: 350 5.7 T.P.I.
Transmission: TH 700-R4
How did you get your car back??
Old Oct 11, 2007 | 04:20 PM
19CAMARO85's Avatar
they never took it instead they are trying to let me keep it but i have to go to court and then let the judge decide if i get the car after 5 months... but they dont know when ill get to go to court so i might get my car next summer... who knows. -Matt
jklein337
Sep 19, 2018 06:23 PM
camaro11j
Sep 19, 2018 08:49 AM
Bryan F
Aug 18, 2015 02:28 PM
tnrednneck
Aug 13, 2015 08:57 AM
