TH 700r4 lock-up
Old Oct 21, 2007 | 10:58 AM
jean's Avatar
TH 700r4 lock-up
Hi All!
I know the topic has already been created but I don't still understand this link
https://www.thirdgen.org/torqueswitch
Do I need only to mount a switch on the diag plug as shown on the picture??
Thanks lot!
Old Oct 21, 2007 | 12:17 PM
MdFormula350's Avatar
Re: TH 700r4 lock-up
you need 2 wires and a switch.
one end of one wire goes to A terminal then that end goes to one switch terminal, then the other wire goes from the other switch terminal to the F terminal on the ALDL port.
when the switch is off (open) nothing happens. then when u turn the switch on (closed) it jumpers both terminals and locks the converter.
Old Oct 21, 2007 | 05:25 PM
jean's Avatar
tell me if I'm wrong, but this system would only work if he ECM is still in the car and functional right??
Old Oct 21, 2007 | 07:35 PM
jaredi's Avatar
Car: 97 Z71
Engine: 350 Vortec
Right. Otherwise you will have to wire up a switch directly to the plug on the trans.
If you're running a carb you'll need to get a vacuum switch as well, unless you wanna flip the switch everytime you want it to lockup.
Old Oct 22, 2007 | 02:33 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
No, it'll work without the ECM, as long as the wiring hasn't been hacked.
Old Oct 22, 2007 | 08:44 PM
jean's Avatar
ok
OK, So it seems that all kind of wiring seems still in the car excepted the ECM wich is gone . So you think I could simply need a swith on the diag connector as the scheme shows and I could be done?
Old Oct 22, 2007 | 08:54 PM
Bandit5's Avatar
This will probably be your most reliable and best functioning solution: http://store.summitracing.com/partde...5&autoview=sku
Old Oct 24, 2007 | 06:00 PM
jaredi's Avatar
Car: 97 Z71
Engine: 350 Vortec
You can make your own setup for about 1/10th the price of that kit, but that kit will work with any 700r, so...
ok
I would try the cheapest stuff first. Try the using the ALDL port, if that doesn't work, try making a direct connection on the trans and using a switch. If that works then you can get a vacuum switch to interrupt the circuit and have what most kits come with. If that doesn't work then you may have to look at something like that painless kit.
Old Oct 27, 2007 | 01:39 PM
buffaloman's Avatar
Car: 1989 Firebird Fornula 350
Engine: 350 L98 / NOS
Transmission: 4sp Auto
What about these kits. Will they work ?
https://www.jegs.com/webapp/wcs/stor...y=OrderItemAdd
loud91rs
Oct 5, 2015 10:05 PM
92projectcamaro
Sep 29, 2015 07:07 PM
IROC ZELLER
Sep 29, 2015 03:00 PM
indygene
Sep 26, 2015 11:21 AM
6998poncho
Sep 25, 2015 02:56 PM
