4th gen 10 bolt
Car: 1990 rs 1992 z28 1995 jeep
Engine: no engine, 383stroker, inline 6 4.0
Transmission: none, t5, auto
4th gen 10 bolt
Im sure i could find this if i had the time too search all the pages so sorry if anyone has too repeat info. The 4th gen 10 bolts are direct bolt-in's correct? There about 2 inches longer on each side?? My main concern is backspacing and wheels ill be running my stock 15" rallys for awhile and i dont want them sticking out past the fender lip is there anyway too get around this? are will it not be a problem? and when i upgrade too 17x9.5 on the rear will they bolt in without spacers?? rims will probably be c5 vette rims im not sure of the back spacing on them off the top of my mind any info would be great.
Re: 4th gen 10 bolt
I'm running a 4th gen 10 bolt (98 to be exact) and I'm running the stock 16's on it and with 245/50's, the outer edge of the sidewall comes almost flush with the outer lip of the fender well. Depending on how stiff your shocks are, you shouldn't have any problems. If you're lowered or have soft shocks, you may have some rubbing.
Car: 92 Trans Am
Engine: 383 Stealth Ram
Transmission: 4L60
Axle/Gears: 3.42/10 bolt
Re: 4th gen 10 bolt
When it comes to wheels, C5 rims work, though with the 18" rears, I need to run a 1/4" spacer minimum...and the tires still rub under hard cornering (yes, all my suspension is after market).
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Re: 4th gen 10 bolt
Thanks alot. Its a 1990 camaro with 10" drums I dont care about the praking break i wont be running one ill be doing C5 brakes in the back and brake stuff is easy enough too do thanks for all the info i just wanted too make sure there dint need to be any bracket relocating and such
ambainb
Apr 25, 2016 09:21 PM
