I hate to ask this...
Car: 89 Camaro RS
Engine: 355 SD TPI
Transmission: WCT5
Axle/Gears: 3.08 Posi
where the hell is the dipstick for the tranny? i have an 89 305 with a t5 tranny and i cant find the dipstick, my foot is broken and in a cast so i cant move around as much. so where's it at? i found the oil on on the passenger side and correct me if im wrong but isnt the tranny dipstick on the driver side close to the firewall?
Car: 86 Trans Am
Re: I hate to ask this...
I don't think there is a dipstik for a manual transmission.
I think its a plug you unscrew and feel if there is fluid upto the plug hole.
I could be totally wrong tho'
**EDIT**
Doh...I almost had the first post.
**EDIT**
Car: 83 Camaro
Engine: 383
Axle/Gears: 4th gen 10 bolt 3:42 POSI
I hate to tell you. There is no dipstick to check fluid lvl on a T5. There is a plug on the passengerside pf the tranny that you fill and check fluid lvl.
Car: 89 Camaro RS
Engine: 355 SD TPI
Transmission: WCT5
crap. I was afraid of that. i live out in queen creek az and its allllll soft powder dirt, filling that is going to suck >_<
Car: 89 Camaro RS
Engine: 355 SD TPI
Transmission: WCT5
ok i got my broken self under the car adn saw 2 bolts, one is next to an oragne warning sticker and the other one is directly above it, i tried both and neither arre coming loose, im not sure what to use but i tried a 3/8 drive ratchet and that didnt work, which one is it and how do i get it off????
TIA
TIA
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
it would be a pipe plug, not a bolt, dont start messing with bolts in the trans,
Car: 89 Camaro RS
Engine: 355 SD TPI
Transmission: WCT5
not like a bolt, my bad didnt mean to call it that, its a plug. And i feel the need to check it because i just bought the car and its kind of a good idea to see what the the last owner screwed up and when you hear gears grinding out of nowhere you think "wow...maybe i should fix that" and common sense says to look at the fluid levels before you do anything
Car: 1989 T-Top GTA
Engine: 5.7L TPI> 6.2L
Transmission: 700R-4
Sounds like your just waiting to screw something up.......... Don't just expect that the last owner wrecked something.
Grab a book or two and start educating yourself son ...... we all started somewhere.........
Don't get me wrong I was 17 once too, and drove things like I stole it
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Common sense says look at the troubleshooting chart in the FSM btw.
Fluid perhaps would be one of the things I checked, say if it only happened when going up hill, or down hill.
-- Joe
Your trans dipstick is attached to your hand (i.e. pinky finger). Lol. The fill plug on a WC-T5 requires a male torx socket to remove, and it's the upper one on the passenger side, about in the middle of the case. If you can't get it loose, try using a small pipe on the 3/8 ratchet for more leverage. If it hasn't been removed in a long time, it's probably pretty damn tight from corrosion, road grime, etc. If the fluid checks out ok, and you're grinding when trying to shift from one gear to the next, either your synchros are starting to go bad in the trans, or your clutch is not disengaging far enough when you shift. You also want to make sure the previous owner put ATF in there, and not 90 wt. gear lube. WC-T5's use Dexron ATF (that's what that orange sticker says). Gear lube messes up the clutch lining on the synchros.
Car: 89 Camaro RS
Engine: 355 SD TPI
Transmission: WCT5
ok well, i just got under there with a breaker bar and busted it out, not literally but its out and my fluid was ridiculously low. there was atf in there so that was a plus and now the grinding is gone after i filled it
luvofjah
Sep 26, 2015 08:28 PM
