tranny rebuild need advice
Old Oct 29, 2007 | 05:34 PM
eschevyrda's Avatar
Car: 89camaro rs
Engine: 350tbi (needs carb!)
Axle/Gears: 32x in process
well im going to get my tranny rebuilt
unfortunately its on a budget
and unfortunately i cant afford the probuilt kit and the labor of the rebuild
so next best thing for my stock 350 89 rs
is
http://www.bulkpart.com/Merchant2/me...roduct_Count=6
has any one used this rebuild kit ?
i herd to stay away from b&m so i will thanks to failures of others.
should i install the corvette servo? i herd it produces hard second shifts that can produces immature wear. and make things worse but i dont know,?
input much appreciated.
Old Oct 29, 2007 | 05:41 PM
Re: tranny rebuild need advice
Yes it is perfectly fine.
You probably DO want to use the Corvette servo. Virtually every high-perf builder uses it. It helps make the transimssion last longer by applying the band tighter. There are other ways of making sure the shift timing isn't set on "kill".
Get the ATSG manual, which they also carry. Unbelievably useful pile of info.
Old Oct 29, 2007 | 05:45 PM
lonman89's Avatar
Car: 1985 chevy camaro IROC-Z
Engine: 5.7 litre 350 4 bolt main
Transmission: 700r w/B&M shift kit
Axle/Gears: 10 bolt w/3:42 gears
i have a B&M shift kit in my 700r tranny and it works fine since my tranny rebuild 6 months ago
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
Stryker412
Sep 7, 2015 09:11 AM
apie2546
Sep 5, 2015 07:40 PM
IROCZ1989
Sep 4, 2015 11:54 AM
mrdevontay
Sep 2, 2015 08:04 PM
