will borg t5 hold up to 500lbs of torque?
Car: 1985 Z28 camaro
Engine: lq4
Transmission: th350
i was wondering if a borg warner t5 5 speed will hold up to 450hp and about 500lbs of torque... building my first race car and trying to figure out a drive train
Car: White 25th Anniversary RS
Engine: lt1
Transmission: t56
Axle/Gears: 4:10
Re: will borg t5 hold up to 500lbs of torque?
Hell no. It will strugle to handle a 305. Go with a t56.
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
yea, a stock t5 will handle 500 ft/lbs for a couple seconds
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Transmission: 4L80 4000, T56
Axle/Gears: 4.30 M12, 23.42 10 bolt
OK, ill tell you, my T5 is behing a 383 with fully ported and polished heas, 10 to 1, XE cam with 238/242 duration, RPM air gap and a holley 750. It is alive so far for some reason, no problems, but i am on radials and a stock clutch. I dont power shift ither. My setup should be around 500 HP. I whooped a 02 firehawk feom a dig, i even have 2.73 with posi, so yea, some hold up to a real motor, some go down in flames behind a 5 litre boat anchor. Sooo....do you feel lucky punk...well do ya? LOL
if it is good shape, it will hold for a while. When it breaks there will likely be nothing left to save, except the shifter. A "beefed" T5 will handle it a bit longer, but will still break, again leaving nothing but the shifter.
If you're looking for race only, kick up an old-school 4-speed. Simplicity and strength for much less than a good T56. If you want to highway it, look into a good T56 or TKO. Personally, I don't like the TKO because it won't powershift.
86TpiTransAm
Mar 2, 2001 11:34 AM
Paul D. '87 IROC 350 TPI
Jan 29, 2001 10:52 AM
