centerforce clutch issues
Old Nov 7, 2007 | 02:37 PM
lightemup440's Avatar
I have an 87 iroc with a ceterforce clutch with maybe 10k on it. I was speed shifting it went to hit 4th and it wouldnt go in i got it and 5th and got home. I now have no clutch it will not disengage the slave seems to be working from what i can see but when i pump the pedal i can shift threw gears with the car running on jackstands.any help will help
Old Nov 10, 2007 | 11:10 AM
Re: centerforce clutch issues
i have posted all over no one can seem to figure it out.
Old Nov 10, 2007 | 12:26 PM
Slave seems to be pushing the distance it needs to but if i was to start car in 1st with clutch fully depressed it would act as i did not have the clutch in making me skip foward.
Old Nov 14, 2007 | 02:09 PM
redliterunner's Avatar
Car: 89 IROC convert.
Engine: tpi 305
Axle/Gears: 3.42 10 bolt
It's probably not the clutch, but the throwout arm or pivot, or possibly the throwout bearing. Start by unbolting your slave cyl, removing the rubber boot on the bellhousing, and fiddling with the arm, and see if you can figure anything out. If you were powershifting a T-5, you may have more than one problem, but the car should still start with the clutch pedal pushed.
theshackle
Sep 17, 2020 08:26 AM
Gambit TA
Sep 1, 2015 07:27 PM
87 camaro iroc
Aug 20, 2015 07:47 AM
Bryan F
Aug 18, 2015 02:28 PM
rsrmoore
Aug 7, 2015 08:44 PM
