Questions About My Rear End
Old Nov 7, 2007 | 05:46 PM
Shotgun713's Avatar
Car: 1987 Pontiac T/A GTA
Engine: 350ci 5.7 liter
Transmission: Stock GTA Tranny
Hey guys i was curious if any of u can help me out, i have a 87 trans am with a 305 4bbl carb and a 700r4 it has a 2:73 gear ratio and ITS NOT A POSI,
Does Any One Know The how many splines these axles have????
Thanks In Advance
Old Nov 7, 2007 | 05:51 PM
gmgod's Avatar
Car: 92 T/A VERT
Engine: LB9
Transmission: AUTO
Axle/Gears: 7.5 / 3.42's
Re: Questions About My Rear End
If it's original and a 10 bolt, 26.
Unfortunatly though, there's no way to tell for sure without pulling one out and counting.
Old Nov 7, 2007 | 05:55 PM
Shotgun713's Avatar
It is a 10 bolt and its all original thanks for the help.
tomorow iam going to be taking apart just wanted to kno a lil b4 i did thanks again
GMGOD by any chance would you kno if i can take out the posi unit (with the ring pinion and etc.) from my 8 bolt rear and put it into the 10 bolt rear end i have right now Thanks
Old Nov 8, 2007 | 08:15 AM
gmgod's Avatar
Car: 92 T/A VERT
Engine: LB9
Transmission: AUTO
If your talking about a 9-bolt. No, you can't.
Old Nov 8, 2007 | 03:28 PM
Shotgun713's Avatar
sry type wrong number its 9 bolt borg warner,
can i take the disc brakes from the 9bolt and put it one the 10bolt with drums i got everything off the 9bolt
Old Nov 8, 2007 | 03:51 PM
No.
The flange where the backing plates mount to the axle tube is different.
But, 10-bolt backing plates are easy to find. And, if your 9-bolt ones are for the good brakes (PBRs), people will pay good money for them. Most everybody that has the crappy Saginaw system would LOVE to trade up to the PBRs, but those plates are somewhat scarce, being a 1 year only deal (89).
If you have the Saginaw system, you'd be better off leaving what you have on there; and keep looking for PBRs.
Old Nov 8, 2007 | 04:56 PM
Shotgun713's Avatar
how can i tell if the brakes are PBR's or Saginam, Thanks Alot for all the help guys
Old Nov 8, 2007 | 05:01 PM
PBR: aluminum, 89-up, both calipers mount behind the axles
Saginaw: cast iron, 88-back, one caliper mounts in front of the axle and the other behind
Pretty easy to tell apart, really.
hectre13
Dec 11, 2023 08:14 AM
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
hectre13
Aug 26, 2015 08:17 AM
AkDrifted
Aug 17, 2015 07:45 PM
BlackBoulder
Aug 11, 2015 11:15 PM
