Nuetral Saftey Switch?
Old Nov 13, 2007 | 12:13 PM
zacharyhorn's Avatar
Car: 91 Firebird
Engine: Turbo 355
Axle/Gears: 3.73:1 7.625" 10 Bolt
Hey guys,
I've searched a little on this, I recently converted my car from auto to T-56 and all is great. I don't have the nuetral saftey switch though. Can anyone tell me where to get one and how to wire it up on my car? Also, how much for the part?
Old Nov 13, 2007 | 04:03 PM
AmorgetRS's Avatar
Re: Nuetral Saftey Switch?
With the T-56/T-5 there is no NSS. They make you push the clutch in instead. I can't really help with the rest though, sorry
Old Nov 14, 2007 | 01:23 PM
vbMike's Avatar
Car: 1987 Camaro IROC-Z28
Engine: TPI 350ci L98
Transmission: T56 - Hurst Shifter
Axle/Gears: BW - 3.70
This is the switch you need. You can get it at advance auto parts or auto zone.
http://www.partsamerica.com/productd...pe=631&PTSet=A
You have to extend the wires that run from the automatic shifter wire harnes to the clutch switch that attaches to your clutch pedal. It should be the two largest size wires on that shifter wire harness.
Old Nov 14, 2007 | 02:56 PM
Car: 91 Firebird
Engine: Turbo 355
Thanks Mike. Do I need a harness to connect it with? Or do I just use connectors to the switch that I can buy anywhere?
Old Nov 14, 2007 | 07:32 PM
vbMike's Avatar
There is a special harness/connector that you can buy but it is like 15 or 20 dollars. I just attached two spade female terminals to the wires that I extended from the factory harness and then just plugged them into the switch. Worked great and only cost a couple dollars. You can pick up a pack of connectors at most any hardware store.
Old Nov 15, 2007 | 03:18 PM
Car: 91 Firebird
Engine: Turbo 355
Thats what I'm planning on doing. Thanks.
Veaceonee
Sep 29, 2016 08:15 PM
RacerM
Sep 28, 2015 04:25 PM
tglennon11
Sep 23, 2015 05:30 PM
327IROC85
Sep 23, 2015 12:11 AM
Randomtask2
Sep 10, 2015 08:37 AM
