t5 need help
Car: 1986,1988,1989 IROC
Engine: ?,L98,383 L98
Transmission: ?,700r4,700r4
Axle/Gears: ?,3.27,3.45
t5 need help
building 383 tpi for 89 iroc and want to put t5 behind it but do not know if it will last.what is/are the weak points of the t5.i've heard the case is weak and will flex.i've also heard it is the gears.i just need to know what i need to do so the t5 will live a happy and health fun filled life behind my 383 without having to spend a fortune on it.
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: t5 need help
the only real solution is very expensive, swap it out to something different and stronger, cost with little parts and such, about 3k on the low side of the scale
you can run the t5, but you will have to baby it, use the clutch when shifting, no power shifting, no clutch dumps and such, at that point, why bother having it.
Car: 86 Trans Am
Re: t5 need help
its small and light, the case flexes and stretches under load, causing the gears to misalign and tear themselves up, mainly 3rd gear
Re: t5 need help
so if a better case is used like the one from g-force and the heavy duty front bearing support would that make it better?????
Car: 86 Trans Am
Re: t5 need help
the conscientious here is that there is no point trying to upgrade a t5, even with the g-force case and expensive gear kits, the same issues occur, though there are a couple people here with the g-force trans missions and they are still holding up, one is almost running 10's. the guys screen name is 5678TA, he is around the dragracing board a lot, you can pm him and get some more input on gforce if you want
Have you priced the gforce transmissions? they are almost 2k, you could get a TKO 5 speed for that much
Re: t5 need help
but with the tko you have to buy adapter plate and other pieces to mate it to you motor where as with the gforce you just bolt it in with no extra cost.
Car: 86 Trans Am
Re: t5 need help
and when it blows up on you, your out 2k, the tko cost a bit more, so does a t56, but they are strong.
like i said, 5678TA has a gforce t5 with the upgraded case and he is almost into the 10's in the 1/4, send him a pm if you want a users review/opinion on the gforce stuff.
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Transmission: 4L80 4000, T56
Axle/Gears: 4.30 M12, 23.42 10 bolt
Re: t5 need help
I have a T5 behind my 383...i beat the **** outta it and for some reason it is still alive...my secret must be a stock clutch and radials with no track use whatsoever....some say im lucky. I have enought power to whoop bolt on LS1s with a 2.73 gear behind it.
Car: 1986 Camaro SC
Engine: 305 TPI Procharged D1SC
Transmission: Tremec TKO-600
Axle/Gears: Moser 12 Bolt 3.73 posi
Re: t5 need help
dont use the t5, it's weak, i had drag radials on my car and after spinning them it didnt like to go in gear, i now have regular radials on it and it's the same thing, tranny has about 8k miles on it, going to get a tko 600 eventually
