Transmission cooler
Old Nov 15, 2007 | 08:39 PM
myTreadZz's Avatar
Transmission cooler
Will a transmission cooler help preserve the life of a tranny?
-Thanks
Old Nov 15, 2007 | 09:16 PM
gapimpin's Avatar
Car: 1991 Pontiac Firebird
Engine: 383 LT1
Transmission: built 700r4 and fuddle 3500stall
Axle/Gears: 4th gen 3.42 auburn
Re: Transmission cooler
all autos should come with one i think... the cooler the tranny runs the longer it will generally last. I also recomend getting a tranny temp gauge if your like me and beat the hell out of it regularly at the track or on the street even... its cheap insurance to make sure you dont toast your trans...
Old Nov 15, 2007 | 11:03 PM
joeblue83's Avatar
Car: 1988 Camaro
Engine: 383 Stroker
Transmission: Probuilt 700 R4
Yes the radiator is a part of the tranny cooler. If you were to put an external cooler on it would lower the temps around 30 degrees and extend the life of the tranny.
Old Nov 28, 2007 | 05:38 PM
myTreadZz's Avatar
Thanks for the help, I will be investing in a tranny cooler and temp gauge
Old Nov 28, 2007 | 05:46 PM
ryan91rs's Avatar
Car: 1991 RS, 84 El Camino conquista RIP
Engine: 5.0 (for now)
Transmission: 4L60
Axle/Gears: 2.xx torsen limited slip & 3.42 ope
or if you run no AC run it through the condenser. lol.
Old Nov 28, 2007 | 06:26 PM
jimdutro's Avatar
Car: 1988 Iroc
Engine: 383 TPI
Axle/Gears: BW 9 bolt 3.27
myTreadZz, one of the best investments you can make for your car is a tranny cooler and a deep pan. I use a deep tranny pan that holds an additional 2 quarts. Since I started using deep pans and coolers I have never had any problems with GM trannys. I put over 200K miles on each of my last 4 El Caminos and 150K+ miles on my `88 Iroc and no trans issues.
Hotrodboba400
Dec 10, 2019 07:07 PM
Zeek1041
Theoretical and Street Racing
Sep 30, 2015 11:00 AM
apie2546
Sep 20, 2015 01:03 PM
scottmoyer
Sep 7, 2015 07:06 PM
apie2546
Sep 5, 2015 07:40 PM
