just swapped th350 wont go in gear?
Old Nov 17, 2007 | 09:57 PM
jlc84cam350's Avatar
Car: 84 camaro, 92 yota 4runner
Engine: 305 lg4 out of 81 z28
Transmission: th350
Axle/Gears: Not sure believe its 3.23
ok just swapped in my th350, it won't go in gear, didn't have a transmission in the car when i baught it, now what overall needs to be hooked up, i have the gearbox selector hooked up, and speedo cable, what else? WHen its put in gear don't eaven tick or nothing. I seen what looks like a vacuum tube, do i really need this to make it work? Any feedback would be great thanks!
Old Nov 17, 2007 | 11:35 PM
Transmission: th350
Re: just swapped th350 wont go in gear?
if i would have mixed the tranny cooler hoses, could that be my problem?
Old Nov 23, 2007 | 10:51 PM
jay_d's Avatar
Car: 84 z28
Engine: 355
Transmission: TH350
Axle/Gears: one wheel peel
should probably try adjusting your shifter linkage first......if its in a thirdgen camaro and your trying to use the stock shifter that could be the problem too.....may need a new valve body
Old Nov 23, 2007 | 10:59 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
The stock shifter will work, it just won't go down into first. The vacuum modulator needs to be connected to a source of manifold vacuum, or else it will think you're at WOT all the time.
Did you put ATF in it?
Old Nov 25, 2007 | 05:41 PM
Transmission: th350
very sorry guys i found the problem didn't have enough ATF. I didn't think so much atf goes in a transmission. I thought 4L tops!! but it turns out when its dry their goes up to 12L, i put 8L in all and she went in fine thanks anyway guys.
1984HO
Mar 19, 2021 11:59 AM
InfinityShade
Aug 22, 2015 08:00 PM
jharrison5
Aug 19, 2015 05:53 PM
mizz0313
Aug 12, 2015 06:45 AM
