89 chevy 1500 700r4 fit a 3rd gen?
Old Nov 19, 2007 | 07:53 AM
Aaron91RS's Avatar
Car: RS
Axle/Gears: 9" for the ladies
Stock one went out would this work to replace it?
Old Nov 19, 2007 | 09:34 AM
84 z28's Avatar
Car: 1984 z28
Engine: 355
Axle/Gears: Moser 9" 4.11
Re: 89 chevy 1500 700r4 fit a 3rd gen?
All 700r4's are interchangeable.
Old Nov 19, 2007 | 04:50 PM
KrisW's Avatar
Car: 88 V6 'bird/89TBI bird/85 T/A
Engine: 2.8/TBI/TPI
Transmission: V8 T-5/700R4 x2
Axle/Gears: 3.42 open/2.73 open/ 3.27 9 bolt
EXCEPT!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
What engine do you have? What year is your car?
2.8/3.1/3.4 V6 use a different bolt pattern than the V8
87 and newer use a 31 spline input shaft for the torque converter and older models sometimes use a 27 spline shaft.
YOU MUST KEEP YOUR TAILSHAFT HOUSING FOR YOUR TORQUE ARM MOUNT!
Other than that, they are pretty much interchangeable...
Old Nov 19, 2007 | 04:54 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Unless it's from a 4wd or Corvette too, in which cast the tailshaft length is different.
Old Nov 19, 2007 | 11:52 PM
Pro Built Automatics's Avatar
1984 1/2 and later are all 30 spline input shafts. You will need to change the tail housing. Make sure the TV cable is adjusted correctly.
Old Nov 20, 2007 | 07:01 PM
87zjeff's Avatar
Axle/Gears: '01 3.42 10 bolt
not quite. as stated by other posters, the v-6 models had a different bell housing. also all v-6, regardless of year, have 27 splines whereas the 84 1/2 up used 30 splines as pro built stated.
Old May 7, 2014 | 07:05 PM
MTL891500's Avatar
How hard is it to change the tail shaft ?
Old May 7, 2014 | 07:20 PM
Chad85T/A's Avatar
Car: 85 T/A
You will probably also need to keep the TV cable from the car to ensure its the right length.
Old May 8, 2014 | 02:32 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
https://www.thirdgen.org/forums/tech...formation.html
The tailshaft or tailshaft housing ?
Big difference
Old May 8, 2014 | 08:21 PM
MTL891500's Avatar
Tailshaft
Old May 8, 2014 | 08:45 PM
Chad85T/A's Avatar
Car: 85 T/A
That's a complete trans tear down. Is the trans out of a 4WD truck?
BADNBLK
Nov 16, 2016 09:12 AM
1992 Trans Am
Exterior Parts for Sale
Apr 4, 2016 12:50 PM
Reddeath210
Oct 6, 2015 08:20 AM
Zeek1041
Theoretical and Street Racing
Aug 21, 2015 08:45 PM
reiderz iroc
Aug 13, 2015 04:57 PM
