drive shaft help
Old Nov 27, 2007 | 12:51 AM
shanemacmahon19's Avatar
drive shaft help
so im putting a tubo 350 in my 84 z28 HO am i going to have to put a new driveshaft in it i know that the 700r4 and the th 350 has the same amount of splines but gow much longet am i going to have to go with the driveshaft and can i use a driveshaft out of a diferent GM car
Old Nov 27, 2007 | 01:05 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: drive shaft help
It would depend on whether you have a long or short tail TH350.
Old Nov 27, 2007 | 01:09 AM
its a short shaft
Old Nov 27, 2007 | 01:14 AM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
You could use the shaft out of a thirdgen with a TH200C.
Old Nov 27, 2007 | 01:17 AM
are those in v 6 or v 8 cars and what years and modles are most likley to have that tranny
thanks for the help by the way
Old Nov 27, 2007 | 09:43 AM
ZZ28ZZ's Avatar
Car: 82 Z-28
Engine: 383 TPI
The TH200C was only used in 82 for third-gen cars.
My 82 Z28 with the Cross-Fire 305 V8 had a TH200C. From what I've pick-up up around here, that's the driveshaft you need. What part of the country are you in? I may still have the driveshaft laying around here somewhere.
According to the "Camaro Tech Data" link on the home page, that tranny was available with 4, 6, and 8 cyls engines. Not sure if the driveshaft from a 4 or 6 cyl would be the right length.
Old Nov 27, 2007 | 11:13 AM
Toehead's Avatar
Car: 1985 Berlinetta
Engine: Megasquirted TPI
Transmission: Transgo 700R4
The driveshaft length should be the same for all engine options IIRC.
Old Nov 28, 2007 | 09:47 AM
well im from ct but id pay for shipping beacuse ive looked aroung here and couldnt find any 82 3rd gens with that tranny and id rather not cut and weld ya know and a new one id pretty expensive
1992rs/ss
16
Jan 28, 2016 09:58 PM
Reddeath210
Oct 6, 2015 08:20 AM
jharrison5
Aug 19, 2015 05:53 PM
Ozz1967
Aug 16, 2015 10:23 PM
transam84
Exterior Parts for Sale
Aug 14, 2015 08:54 PM
