will a 700r4 that is meant for a 4wd truck fit in my trans am
Old Nov 27, 2007 | 05:56 PM
adk683's Avatar
i bought a trans awhile ago for my 4wd truck but turned out i didnt need a tranny and i sold the truck and i still have trans it is a brand high performance tranny will it swap right in or will the tailshaft be different
thanks for the help
i am new to this forum
Old Nov 27, 2007 | 06:04 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: will a 700r4 that is meant for a 4wd truck fit in my trans am
The tailshafts are different.
Old Nov 27, 2007 | 06:05 PM
87zjeff's Avatar
Axle/Gears: '01 3.42 10 bolt
the output shaft is too short to work in your trans am and the tail housing is different. you would have to take it apart to get the right parts in there.
Old Dec 1, 2007 | 01:30 PM
adk683's Avatar
would that be easy to do or not worth it
Old Dec 1, 2007 | 01:41 PM
87zjeff's Avatar
i consider it easy, but i work with transmission parts and have built a few 700r4's. if you have never been into a transmission before, it can be a challenge. it's not rocket science or anything but "easy" is a term relative to experience and abillity.
Old Dec 1, 2007 | 01:43 PM
adk683's Avatar
ok well lets say price wise is it worth it and could i just use my stock parts or should i upgrade
Old Dec 1, 2007 | 01:50 PM
87zjeff's Avatar
the shaft and tail housing are cheap for factory replacements especially if you do the work yourself. the only aftermarket shaft i have heard of or seen is a $400 shaft from patc that is supposed to be stronger than the factory shaft but you have to be running one big motor to break the factory one. the housing itself i only know of the factory one.
Frozer!!!
Jan 19, 2024 04:55 PM
BlueIroc-Z
Jun 9, 2019 03:22 AM
camaro11j
Sep 19, 2018 08:49 AM
Reddeath210
Oct 6, 2015 08:20 AM
Leggman1
Aug 6, 2015 04:15 AM
