What fluid should I be using in a 89 Pontiac trans am T5?
Car: 88 Mazda RX7
Engine: 305- Headers, -680cfm Quadrajet,-flex-a-lite dual fans
Transmission: t5
I have always though that it should be a gear oil. GL-3.
Then I just heard that some T-5's should be using ATF. Whats up with that?
Also, do you guys have any tips about jiggling the T5 into the bell housing? It doesn't seem to want to line up even with the tool.
Thanks guys!
Thanks guys!
Re: What fluid should I be using in a 89 Pontiac trans am T5?
Should be ATF in that trans model (2nd design T-5).
Not sure "what's up"? That's just the way it is.
Car: 89 trans am GTA,90 model trans am 350 tuneport,87 firebird
Engine: 355 small block
Transmission: 5 speed,auto 700r4
ATF in the 1989 T5
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Car: 88 Mazda RX7
Transmission: t5
What ATF are we talking?
+4, Mecron/Dexron 2, 3, or 5?
EDIT: Nevermind, found it Dextron II
Thanks guys!
Thanks guys!
Dex 2 is obsolete. Hasn't been made in years. You can't buy it any more AFAIK. At least, I haven't seen any on shelves for about 10 years or something.
Any kind is fine.
Car: 88 Mazda RX7
Transmission: t5
But wait, isn't this saying I need Dex II? Im lost.
Sorry for resurrecting this post, but the advice given is somewhat innaccurate and may cause somebody's T-5 damage.
The '83 to '87 Camaros had the NWC-T5 (NonWorld Class T-5) or sometimes referred to as the STD-T5 (Standard T-5) transmission. This tranny's blocking rings used brass (some say bronze) synchronizers.
This tranny did use 70W gear oil.
The '88 to '92 Camaros had the WC-T5 (World Class T-5) transmission. This tranny's blocking rings use fiber synchronizers. These required the use of ATF fluid (Dextron II) as gear oil could cause them damage.
Z28er had an '84, and if the tranny is original (NWC-T5), it would have taken 70W gear oil, not ATF.
So, somebody that doesn't really know what they're talking about, posts something somewhat inaccurate on the Internet (I know, I know, you can't post things on the Internet if they're not true, right?), maybe a long time ago.
Will that cause the oil companies to go back and begin producing a fluid that's been superseded for a decade or more now?
I'm guessing ..... probably not.
Use what you can get. It doesn't matter. Better than running it dry.
Car: 90 Firebird Formula
Engine: LO3
Axle/Gears: 3.08 one wheel peel
dexIII is backwards compatible IIRC
Car: 88 Mazda RX7
Transmission: t5
ok cool, so any ATF will work.
Thanks Guys!
I can finally drop this 350/T5 into my Mazda lol
Thanks Guys!
Car: 1985 Berlinetta
Engine: Megasquirted TPI
Transmission: Transgo 700R4
Good luck, that is going to haul!
I'llrocya
Feb 2, 2016 11:43 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
