HELP!!!! NO BRAKES!!!!
Old Dec 8, 2007 | 04:16 PM
goomaan's Avatar
Car: 1987 IROC-Z
Transmission: 700R Auto
We just installed a rear on my 91Z. Let me first start by saying yes I over did it with the gears but the price was too good to pass on.
We removed my old rear which was a 2.73 drum and replaced it with a 4.10 EATON POSI Disc. Replaced all brake lines, proportioning valve (OEM), new callipars and rotors. Put it all together and it goes pretty fast... The probem is the rear brakes are not working now.
I had to use the old eBrake cables that was attached they do not really work right now. Ordered new OEM eBrake cables from GM.
Can the fact that the eBrake cables do not wotk be the reason why I am not stoping?
Should I have changed the master cylinder because I added discs to the rear?
HELP please!!!!
So far I have not modified the motor. I know this has nothing to do with the brakes not working but I know someone is going to ask....
Old Dec 8, 2007 | 04:38 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: HELP!!!! NO BRAKES!!!!
Which rear brakes do you have now?
Old Dec 8, 2007 | 05:01 PM
goomaan's Avatar
Car: 1987 IROC-Z
I have OEM Discs
Old Dec 8, 2007 | 07:45 PM
Jay_rich's Avatar
Car: 1987 Z28
Engine: 2005 5.3L, LS6 Cam
Axle/Gears: DTS 9" 3.50 TrueTrac
Originally Posted by goomaan
I have OEM Discs
What year rear end?
Jay
Old Dec 8, 2007 | 08:07 PM
goomaan's Avatar
Car: 1987 IROC-Z
That's part of the problem. I was told by the guy I got it from that it came off a '91 Z28.
I got the rear from a speed shop that was closing up.
Old Dec 8, 2007 | 08:20 PM
Jay_rich's Avatar
Car: 1987 Z28
what do the brakes look like...LT1 style?
Jay
Old Dec 8, 2007 | 08:29 PM
goomaan's Avatar
Car: 1987 IROC-Z
They look the same as the fronts. Not LT1 style
I do not have the car here now or I would send you a picture.
The whole no brakes thing I chose to leave it the shop..
Old Dec 8, 2007 | 08:51 PM
Jay_rich's Avatar
Car: 1987 Z28
this is from a 91...to the right the shitty 10 bolt ...the left is a moser 12 bolt
Jay
Old Dec 8, 2007 | 09:02 PM
goomaan's Avatar
Car: 1987 IROC-Z
Yep it looks just like that..
Can you offer any advise?
Does anyone have a thought on this...
Old Dec 9, 2007 | 05:44 PM
goomaan's Avatar
Car: 1987 IROC-Z
TTT
HELP!!!!!
Old Dec 9, 2007 | 06:18 PM
Toehead's Avatar
Car: 1985 Berlinetta
Engine: Megasquirted TPI
Transmission: Transgo 700R4
Is everything bled properly back there?
Old Dec 9, 2007 | 07:15 PM
funkdubie's Avatar
Car: 85 z28
Engine: 355ci
Transmission: th400
the back doesn't hold at all?
Old Dec 9, 2007 | 09:11 PM
goomaan's Avatar
Car: 1987 IROC-Z
Yes everything is bled.
They are gripping a little very little.
I am thinking the proportioning valve I got must be bad.
Old Dec 9, 2007 | 09:36 PM
mcgarnicle's Avatar
Car: 1991 Z28 1LE
Yeah if you went from drum to disc you should change the prop valve
Old Dec 9, 2007 | 09:42 PM
goomaan's Avatar
Car: 1987 IROC-Z
Did change it actually had to add it. Do I need to ugrade the master cylinder?
Old Dec 9, 2007 | 09:51 PM
mcgarnicle's Avatar
Car: 1991 Z28 1LE
you shouldn't need to, how do they work with the new prop valve?
Old Dec 9, 2007 | 09:53 PM
goomaan's Avatar
Car: 1987 IROC-Z
They don't!
Old Dec 10, 2007 | 04:47 PM
mcgarnicle's Avatar
Car: 1991 Z28 1LE
Does that rear end have rubber lines from the hard line to the calipers? Those get kinked pretty easlily and can cause failure.
Old Dec 10, 2007 | 05:16 PM
TheBigJ's Avatar
Car: 85 Firebird
Engine: SBC 383/88BW
Transmission: Built 700R4
Axle/Gears: Moser 9in/3.55
I would check to make sure you are getting good flow when you hit the brakes (after you bled thme) I've seen those solid brake lines kink up when the rear is lifted.... so i just got new lines
Old Dec 10, 2007 | 08:03 PM
goomaan's Avatar
Car: 1987 IROC-Z
I am waiting on the new brake lines to come in.
Old Dec 11, 2007 | 08:17 PM
funkdubie's Avatar
Car: 85 z28
Engine: 355ci
Transmission: th400
i'm not certain on this, but i think (heard somewhere) that the master cylinders are different from 2w disc to 4w disc cars and the 4w disc master is a higher pressure for the rear and that a prop valve alone won't cut it..i have a similar situation on mine although not as bad.
Old Dec 11, 2007 | 09:17 PM
goomaan's Avatar
Car: 1987 IROC-Z
I noticed when I was looking for parts that the master for 4w disc was different. I am sure that is probably it.
I was able to get about 75% brakes out of the rear. Next thing to change is the master.
Old Dec 13, 2007 | 05:08 PM
TheBigJ's Avatar
Car: 85 Firebird
Now that you mentioned it, I do recall reading a thread on another forum over this issue, you should still get basic brakes tho, hopefully those new lines help some
Old Dec 13, 2007 | 05:22 PM
funkdubie's Avatar
Car: 85 z28
Engine: 355ci
Transmission: th400
please keep us updated as to whether or not the new master cylinder fixes the problem so I can follow your lead and do the same....
BADNBLK
Convertibles
Sep 21, 2015 07:56 PM
dbrochard
Sep 19, 2015 08:13 PM
Necron
Brakes
Sep 14, 2015 12:45 PM
Buickstaged
Brakes
Sep 4, 2015 07:53 AM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:50 PM
