T56 Clutch question
Car: 1992 Z28 1LE
Axle/Gears: SLP dana 44 3.92
T56 Clutch question
i think i might have intsalled my clutch disc backwords.
when you set the clutch against the flywheel and bolt the pressure plate down, which way to you put the disc in? with the spring assemblys down in the flywheel? or the spring assemblys out toward the pressure plate?
if anyone has pictures of this please, they would be alot of help.
Car: 91rs
Engine: 6.0
Transmission: 4l60e/3600 vig stall
Axle/Gears: 3.73 9 bolt
Re: T56 Clutch question
there should be a sticker or some writing on the clutch disk that says which way to put it. i have a centerforce df clutch(sitting on the floor in my garage right now) and when bolted down, the spring assembly is towards the flywheel side.
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
If you have T-56 factory type clutch the springs go in to the flywheel.
rsrmoore
Aug 7, 2015 08:44 PM
