Shifting Problem?
Old Dec 26, 2007 | 01:48 AM
Jb87IROC's Avatar
Shifting Problem?
I noticed my auto IROC has a very brief "chirp like" over rev when shifting from 2nd to 3rd. I've had the problem since I purchased the car, hasn't gotten better or worse really. The tranny catches fine and shifts through all the gears strong, but just has this momentary "chirp". I also notice that it down shifts hard and quickly from 3rd to 1st when rolling to a stop light. When I bought the car I was told it had a shift kit, but are these normal characteristics?
Old Dec 26, 2007 | 07:18 AM
lonman89's Avatar
Car: 1985 chevy camaro IROC-Z
Engine: 5.7 litre 350 4 bolt main
Transmission: 700r w/B&M shift kit
Axle/Gears: 10 bolt w/3:42 gears
Re: Shifting Problem?
yea thats the shift kit doin that,my iroc has a B&M shift kit and it shifts strong and chirps the tires when shifting
Old Dec 26, 2007 | 10:13 AM
Pro Built Automatics's Avatar
The "over rev" is not good, it is a 2-3 shift flare. It means that the 2-4 band is coming off "completely" before the 3-4 clutches start applying. When does this happen? at WOT? or at part throttle? Make sure that the TV cable is tight at WOT. Do this and see if it makes a difference.
Old Dec 26, 2007 | 03:43 PM
codemonkey's Avatar
Car: 84 Trans Am
Engine: 305 HO
Transmission: 700R4 soon to be a TH350
I don't see how chirping between gears is a transmission issue, you need stickier tires if u want it to stop doing that. The point of shift kits is for quiker and stronger shifts which would decrease torque lossed during shift, thats what's causing the chirping.
Old Dec 26, 2007 | 04:39 PM
Jb87IROC's Avatar
Yes, I mean shift flare. I just didn't know the term for it . The flare happens under normal acceleration. I can suppress A LOT by adjusting the cable, but it is still there. How do I fix the issue?
Old Dec 26, 2007 | 07:19 PM
Blue-Beast's Avatar
It's taking too long for the 3rd clutches to engage.
Pull the pan, drop the 3rd gear accumulator, and remove the piston. Take out the spring (the spring is a cushion) and install a stack of washers to take the spring's place. The accumulator piston should be just below the surface of the housing. Put it all back together and pour in a bottle of Lucas addative.
Gauranteed, you'll have a better 3rd gear shift.
someone972
Aug 30, 2015 12:52 AM
Frismund Snoid
Aug 27, 2015 11:08 AM
crazynights
Aug 21, 2015 06:53 AM
dhonda200
Aug 11, 2015 11:50 PM
