TH400R stays in Reverse when shifter is put in Park
Old Dec 28, 2007 | 03:21 PM
JWKbride's Avatar
Car: 1992 Pontiac Trans Am Convertible
Engine: 305 H.O.
My 92 TA will not go into park. Although the selector moves to the "P" position and it feels like it's in park its really in reverse. When I start the car I keep my foot on the brake and all is well (I have 2200 stall converter) but as soon as I take my foot off the brake it start to move.
When I park the car and turn it off (with selector in "P") the transbrake does not engage and I have to make sure I have the parking brake on or the car will roll back.
That said, any suggestions before I take it to my local Transmission shop? Could it be a linkage has come loose or broke? Other than this problem the transmission performs as it should.
Old Dec 29, 2007 | 03:58 PM
87zjeff's Avatar
Axle/Gears: '01 3.42 10 bolt
Re: TH400R stays in Reverse when shifter is put in Park
is this the factory one that is in your TA or did you swap it out? a th400 is not an a4. also, trans brakes do not hold a vehicle from moving in the park position,the parking gear/rod/and lever do that.
Fronzizzle
Mar 18, 2019 08:29 PM
camaro11j
Sep 19, 2018 08:49 AM
hokis
Aug 9, 2015 03:57 PM
