6 speed swap
Re: 6 speed swap
A stock untouched unmolested LT1 flywheel is the same balance as a 305 or 350 from 86 up. Bolts right on.
If the flywheel's balance has been dinked with, though, all bets are off. You'd have to check with wohever sodomized it, and see what they did and either get them to undo it or get someone else to make it back stock, or you'd have to get another one.
Re: 6 speed swap
Brand names and "internal" are of no use.
If it's stock and untouched, it will work.
If it is not stock and has been worked on by someone making it into something non-stock, whether they throw the word "internal" around or not, it will NOT work.
This is not all that complicated.
1992 Trans Am
Aug 8, 2015 08:16 PM
