Tranny not pumping fluid
Old Jan 23, 2008 | 08:12 AM
bakerstreet's Avatar
1992 rs 305 with factory everything
what could be the problem if the tranny is not pumping fluid, & tranny will not shift, first & reverse works fine, but will not shift out of first gear.
tranny had been leaking from the front of the tranny, & when it got cold the other day, it just stopped shifting, it is full of fluid.
if the tranny pump was bad would first & reverse still work?
what else could be the problem?
Old Jan 23, 2008 | 12:37 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: Tranny not pumping fluid
What makes you say it's not pumping fluid?
Old Jan 23, 2008 | 03:20 PM
Pro Built Automatics's Avatar
If this happened all at once, take off the governor cover and remove the governor and you most likely find that the teeth are broken or stripped. This is common.
Old Jan 23, 2008 | 03:24 PM
because it's not leaking from the front seal area anymore,
it only leaked when the engine was running & the car was shifting ok,
now it doesnt leak & doesent shift.
Old Jan 26, 2008 | 01:21 PM
hwcoll95's Avatar
Car: 1989 Iroc rebuild
Engine: 355 carb'd
Transmission: 5spd
Axle/Gears: 3:08 pos for a while
pull line at radiator and see if any fluid comes out running,that'll tell ya
Old Jan 26, 2008 | 08:05 PM
BadBrains420HR's Avatar
Car: 1982 Firebird S/E
Engine: stock
hey if first and reverse is running then shouldnt that mean that the tranny is pumping fluid?
backtothe80s
Sep 5, 2015 12:39 AM
z28_AJ
Aug 27, 2015 08:59 PM
Thornburg
Aug 25, 2015 01:46 AM
spaigo
Aug 21, 2015 07:46 PM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
