strange dana 60 question?
Old Jan 24, 2008 | 09:47 PM
jeff lucas's Avatar
Car: 92 camaro rs
Engine: 383 stroker (518 hp)
can i use my stock brakes set-up with this rear-end
Old Jan 24, 2008 | 09:58 PM
ploegi's Avatar
Car: 1988 Pontiac Firebird Formula
Engine: 5.7 TPI
Re: strange dana 60 question?
Just to hazard a (relatively accurate) guess, I would have to say....... No. Are there any brakes on the rear now? What are your current rears? Do the axles even have the same bolt pattern as your current rear? What did you plan to do about that? Unilugs? (please dont.)
Old Jan 24, 2008 | 10:09 PM
jeff lucas's Avatar
Car: 92 camaro rs
i dont have any plans, i am trying to put a car together without any knowledge on what goes with what. i have a stock rear on a v6 92 camaro fix'n to get a 550 horse motor put in it and i need to change out the rear and and didn't know if this type of rear end needed a set of brakes to go along with it
Old Jan 24, 2008 | 10:15 PM
ploegi's Avatar
Engine: 5.7 TPI
OOoooo, THAT is going to a bit of a change.....
If you have the cash, best bet is to order a 12 bolt, or, Ford 9 inch from one of the many companies that build them. It has the advantage of being a direct bolt in. Pricey, but, you would prolly spend about the same trying to get the 60 to work.....
With that kind of horsepower, I would highly recommend things like sub-frame connectors, and some beefier suspension components as well....
Old Jan 24, 2008 | 10:32 PM
jeff lucas's Avatar
Car: 92 camaro rs
its going to be quite a change, i drove this car around the block once then started ripping things of of it. i've been buying parts little by little including some of the suspension parts that u have mentioned, with that 12 bolt u mentioned being a direct bolt on does that include bolting the brake system back on or do i need to save for that as well
Old Jan 24, 2008 | 10:41 PM
joshh44's Avatar
Car: 1990 T-Top Camaro RS
Engine: engineless
Transmission: Trannyless
Axle/Gears: 10 bolt/3.08. soon to be axleless
here is a 12 bolt rear kit from spohn.
http://www.spohn.net/?action=product&pid=1320
im debating on getting one or not.
Old Jan 24, 2008 | 10:47 PM
ploegi's Avatar
Engine: 5.7 TPI
Check out Moser Engineering. OR Currie.
Pricey, but, I am sure other folks can chime in here as well, with some alternatives. Maybe..... Make sure you are sitting down when looking at prices, and for god's sakes, don't be drinking anything that you don't want to have to clean off your monitor......
Old Jan 24, 2008 | 10:52 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Even I don't need a monster of a diff like a Dana 60. A 9" or 12 bolt is more than enough.
Old Jan 26, 2008 | 11:59 PM
neagan's Avatar
Car: 1988 IROC 5.7 Money Pit
Engine: (being built; modified TPI ZZ4
Transmission: 2200 stall/ stage 3 700R4
Axle/Gears: freshened 3.27 in 9.bolt/
Hey Stephen! I thought you were using an aftermarket rear end???? Did you actually use a Borg Warner 9-bolt at any time??? (Mine just shredded with only 200hp & I had just completely rebuilt it end to end...) Nitro
Old Jan 27, 2008 | 12:36 AM
AlkyIROC's Avatar
Car: 87 IROC L98
My car originally had a 9 bolt. I then swapped in a 10 bolt for a better gear selection. Then I installed a junkyard 9" with ladder bars. The car now has a junkyard homebuilt narrowed 9" with a 4-link
sailtexas186548
Jan 19, 2016 12:21 PM
red90IROCls1
Aug 25, 2015 06:56 AM
redmaroz
Aug 16, 2015 11:40 PM
sailtexas186548
Brakes
Aug 13, 2015 11:47 AM
MENINBLK
Aug 5, 2015 11:58 PM
