Wait to do both trans & engine mounts?
Old Jan 24, 2008 | 03:25 PM
BOSS 357's Avatar
Car: 89RS,89TBI FB, 91Z28, 89TPI FORMULA
Engine: 357 SBC TPI
Transmission: World Class T-5 (for now)
Axle/Gears: Strange 12-bolt 3.73
I have a TPI mated to a WC T5. Both the engine mounts and trans mounts are s.h.o.t. There's very little supporting the engine and my trans wobbles a good bit on most roads.
I bought a poly engine/trans mount set from ES. I was planning on doing the trans mount now and doing the engine mounts when I retool the front suspension (read: remove the a-amrs). My quandry is that I've read if you replace the trans and not the engine mounts, that may eff up the driveline or offset how everything sits under the car/hood. Anyone agree with that? I'd like to do the trans NOW (yesterday) and save the engine for later, how bad would things be messed up if I did?
Thanks,
Eric
Old Jan 24, 2008 | 03:40 PM
KrisW's Avatar
Car: 88 V6 'bird/89TBI bird/85 T/A
Engine: 2.8/TBI/TPI
Transmission: V8 T-5/700R4 x2
Axle/Gears: 3.42 open/2.73 open/ 3.27 9 bolt
Re: Wait to do both trans & engine mounts?
I did it that way and didn't have any problems with my 87 Formula.
The poly trans mount sometimes throws off the driveline angle all by itself. Sometimes they come with a spacer plate. Mine didn't, but some people did get them and sometimes they were okay, sometimes they had to be removed.
I wouldn't run it, myself. Just put the poly mount in. You will notice a little more vibration coming through the shifter, but hey, it's a compromise!
If your stuff is really bad, you'd better check your torque arm mounts as well. They may be pretty beat up after floating around in there with trashed engine/trans mounts.
Old Jan 25, 2008 | 05:39 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Me either. Even if you have problems, swapping the tranny mount is a half hour job.
JamesC
Old Jan 25, 2008 | 11:09 AM
Achoo's Avatar
Yeah, I've had to do it a few times and the hardest part is jacking up the car and then jacking up the trans a little to relieve the pressure
colton_carlson
Mar 8, 2019 12:21 PM
MoJoe
Fabrication
Aug 19, 2017 07:12 PM
jharrison5
Aug 19, 2015 05:53 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
Elliswon
Aug 10, 2015 12:33 PM
