Switching to a 12 bolt
Old Jan 24, 2008 | 10:41 PM
joeblue83's Avatar
Car: 1988 Camaro
Engine: 383 Stroker
Transmission: Probuilt 700 R4
I want to upgrade to a 12 bolt from my current 9 bolt rear. I know that the brakes are not a direct bolt in for the 12 bolt, so what do i need to do and get to make my 9 bolt rear disc brakes to work
Old Jan 25, 2008 | 05:47 PM
hwcoll95's Avatar
Car: 1989 Iroc rebuild
Engine: 355 carb'd
Transmission: 5spd
Axle/Gears: 3:08 pos for a while
Re: Switching to a 12 bolt
$$$$$$$ who has 12 bolts for these 3rd's as bolt in??
Old Jan 25, 2008 | 06:04 PM
joeblue83's Avatar
Car: 1988 Camaro
Engine: 383 Stroker
Strange makes a direct bolt in for our cars. costs around 2000
Old Jan 25, 2008 | 06:09 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Strange and Moser both make 12-bolt setups designed for the 3rdgen F-bodies. Mosers have lots of options when ordering to set it up how you want, and I'm sure Strange does as well.
Old Jan 26, 2008 | 03:23 PM
383backinblack's Avatar
Car: '91 Camaro RS
Engine: F1R Procharged 383
Transmission: Tremec 600
Axle/Gears: moser 12 bolt, 4.11's 33 spline axl
i have a moser.....with 9" big ford bearing housing ends......you can use the stock 9 bolt break setup, but you have to redrill the backing plate to fit on the housing end and use a shim for the bearing retainer......its not that hard to do.
Old Jan 27, 2008 | 03:37 PM
Air_Adam's Avatar
Why not convert the rear end to use 4thgen disc brakes? The components aren't expensive, and it seems like a pretty popular upgrade to these cars when you upgrade to a 12-bolt or 9" rear end. Moser can sell you a housing and the brackets to make the 4thgen discs a bolt-on deal. They work well too.
Old Jan 27, 2008 | 03:57 PM
Car: '91 Camaro RS
lots of grinding to fit a 15" weld rim on there for drag racing with those brakes
89GTAOz
May 16, 2020 09:31 AM
Dkelz313
Apr 7, 2016 10:38 PM
Dialed_In
Aug 20, 2015 01:45 PM
355sbcTPI
Aug 19, 2015 04:38 PM
dcbsracing007
Aug 18, 2015 07:24 AM
