4th gen rear
Old Jan 25, 2008 | 08:39 AM
84 z28's Avatar
Car: 1984 z28
Engine: 355
Axle/Gears: Moser 9" 4.11
4th gen rear
I am wondering what would be better for my car and most cost effective. Re build the 10bolt i have and put in posi,3.73 gears,new axles. Or by a 4th gen for $350 it already has posi and a 3.42 gear and freshin it up. And how hard is it to get the 4 gen in my 84 Z28?
Old Jan 25, 2008 | 09:17 AM
ploegi's Avatar
Car: 1988 Pontiac Firebird Formula
Engine: 5.7 TPI
Re: 4th gen rear
The 4th gen is 2" wider. But, should bolt right in. May have to "adjust" the brake lines, some had 4 circuit ABS, and independently controlled rear brakes. Also, I am unsure of the E-brake cables.
Old Jan 25, 2008 | 05:59 PM
hwcoll95's Avatar
Car: 1989 Iroc rebuild
Engine: 355 carb'd
Transmission: 5spd
Axle/Gears: 3:08 pos for a while
Re: 4th gen rear
go 4th,priced posi chunks,axles,bearing kit,already more $$ than the 4th swap
Old Jan 25, 2008 | 06:23 PM
1987_Z28's Avatar
Car: 1987 Z28
Engine: 355
Re: 4th gen rear
the 3.42s in an auto if thats what u have is plenty high 3.73 are nice if u like no gas milage and not driving on the highway. if ur gunna do the swap make sure u have the resources and read the tech articles they help alot. other then that all i can say is its a direct bolt in and try to get a rear out of a car that didnt have traction control. good luck and my votes for the 4th gen rear. o almost forgot the 4th gen rear will cost so much less then doing all that to ur 3rd gen rear.
its also a good opertunity to throw in a umi ajustable panhard bar.
Old Jan 27, 2008 | 10:06 AM
84 z28's Avatar
Car: 1984 z28
Engine: 355
Re: 4th gen rear
OK so im going towards the 4th gen rear. I have found one for $350. My question is are these rearends only as good as are 3rd gen rears because thats what im hearing. Im pushing out 400hp and I dont want to replace everything if I romp on my car a couple times. The rear is out of a 2000 WS6 Transam how go is this rearend and yes it does have traction control on it.Thanks for the help.
With my current combo I am suppose to have a minimum of a 3.73 gear and I do have a 3000 stall. Will the 3.42 gear be able to get me into my powerband fast enough ?
1992rs/ss
Jan 31, 2025 05:10 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
1992rs/ss
16
Jan 28, 2016 09:58 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
THABADGUY
Brakes
Aug 11, 2015 03:43 AM
