t5 swap
Old Feb 3, 2008 | 01:05 AM
vasquezmrysvll's Avatar
Car: 1985 California Iroc
Engine: HSR ZZ4 0411 swapped
Axle/Gears: 3.23 posi
t5 swap
can anyone here give me a detailed list of parts needed to swap out a 700r4 for a manual trans,in a 85 iroc w/ tpi 305. thanks art
Old Feb 3, 2008 | 01:50 AM
phillip_helmet's Avatar
Car: '84 Camaro
Engine: 5.3l TSP 224r
Transmission: TH350 3600 stall
Axle/Gears: LS1 3.23
Re: t5 swap
There's a technical article about this. You can get to it from the main page.
Old Feb 3, 2008 | 02:05 AM
Re: t5 swap
thanks, do you know if my ecm will "act funny" with the swap?
Old Feb 3, 2008 | 02:10 AM
Car: '84 Camaro
Re: t5 swap
Maybe, maybe not. More than likely it won't do anything noticeable. I'm not 100% sure though; I've only done the swap on a carbureted engine. Do a search, I'm sure someone has answered this before.
Old Feb 3, 2008 | 03:38 AM
jsel's Avatar
Car: 1989 iroc conv
Engine: L03 TBI
Transmission: 700R4 soon to t5 from hawks
Re: t5 swap
the ecm is not that smart you need to make sure that you are using the right gears for the mpr gage. and of course you hook up the right wiring for the nuteral start sweat and brake light
Old Feb 8, 2008 | 06:43 PM
z28gsxr's Avatar
Car: 91 RS Vert/98 Sierra9
Engine: 5.7/5.0
Transmission: 5spd/auto
Axle/Gears: 4th gen rear with 3.73
Re: t5 swap
I have a question about this. i have a 91 RS TBI vert. I believe the speedometer for this is electronic or vsomething whatever they call it and the one on the 85 is mechanical. will the speedometer from the 91 RS work with a t5 from a an 85z28?
Old Feb 8, 2008 | 07:32 PM
400Z28Racer's Avatar
Car: 85 IROC-Z
Engine: magflatoVE
Axle/Gears: 9" 411
Re: t5 swap
you need to use vss sleeve out of 90+ T5 Camaro, or you can use one out of T5 Firebird but i am not sure when Firebird did have VSS T5
Old Feb 8, 2008 | 07:39 PM
z28gsxr's Avatar
Engine: 5.7/5.0
Re: t5 swap
thanx 400
Old Feb 12, 2008 | 02:48 PM
z28gsxr's Avatar
Engine: 5.7/5.0
Re: t5 swap
400 is this the part you mean http://www.autozone.com/R,APP515994/...ductDetail.htm
Old Feb 12, 2008 | 04:42 PM
Car: '84 Camaro
Re: t5 swap
I've got a spare VSS I'll sell you for considerably less than Autozone. PM if you're interested.
Old Feb 12, 2008 | 04:50 PM
z28gsxr's Avatar
Engine: 5.7/5.0
Re: t5 swap
you have a pm
E Rod
Aug 28, 2015 05:17 AM
theshackle
Aug 22, 2015 06:52 PM
Hello, Michael
Aug 20, 2015 03:19 PM
jharrison5
Aug 19, 2015 05:53 PM
355sbcTPI
Aug 19, 2015 04:38 PM
