another 700r4 question
Car: 81z-28,89gta,91z-28 03 1500
Engine: 355,L98vette tpi,327
Transmission: TH350/700R4/700r4/4l80E
Axle/Gears: 3;73/3;27/2;73/3;73
I have recently picked up a 91 v6 bird with a 700r4,and when I put it in drive it doesn't move.
If I move the shifter all the way down to first it will then move and it also has reverse.
I have another good trans. in my garage that I could replace it with,but I was just wondering if someone that knows these trannys well,could tell me if there is something I could replace in it instead of having to remove the trans. itself.Yeah,I'm looking for an easy way out.
Re: another 700r4 question
Anyone?
Wheres the tranny gurus at?
Could it possibly be the pump or something else internal that I could swap with my good transmission instead of replacing the bad one in the car?
I know that someone has to know what the problem is.
Transmission: 4L80E/4L80E
Guess where the pump is, and what you have to do to replace it.
Yup, remove the tranny.
If you have a good one you can put in, that's the easiest possible fix.
alright,thank you.Like I said,I'm not to familiar with the internals of auto. trannys.Looks like I don't have an easy way out after all.LOL
Car: 1982 Camaro
Engine: 454
Transmission: TH350
Axle/Gears: 410
Check the pan bolts that hold the shift cable/bracket in place. I have seen them loosen up and cause the same symptoms.
Iroc8t8
May 4, 2026 08:09 PM
