Please help! 4th Gen Rear
Old Feb 29, 2008 | 04:27 PM
crazyL's Avatar
Car: 85 T/A
Hey guys I have no choice right now but to upgrade to a 4th gen rear! What do I need besides the rear. My friend has the rotors, pads and calipers. He said i need an E brake cable. What do i need and is there anything i will need that he didnt mention. Thanks guys. I need this help asap as i dont have a car right now!
Old Feb 29, 2008 | 05:00 PM
Re: Please help! 4th Gen Rear
Right; you'll need parking brake cables.
If the rear has 4-channel ABS, you'll have to re-plumb the brake hydraulic lines on it, because it will have 2 separate ones where you'll need only one.
Other than that, some brake fluid, some new rear end grease, some silicone for the pan. Maybe a new rubber line or springs or sway bar bushings & end links or whatever else you disturb in the process that you'd like to renew while you're already there.
Old Mar 1, 2008 | 05:34 AM
mcgarnicle's Avatar
Car: 1991 Z28 1LE
Everything you need is in here:
https://www.thirdgen.org/forums/faq-...-gen-rear.html
Old Mar 1, 2008 | 12:52 PM
crazyL's Avatar
Car: 85 T/A
where can i get the parking cable breaks?
Old Mar 1, 2008 | 01:07 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
you can order them online or possibly some auto stores will carry them. I know my local pepboys didnt have the part number i wanted but could order it in for me. I still have to get those cables. I've been running without the rear brake cables for a year and a half
Old Mar 1, 2008 | 01:12 PM
crazyL's Avatar
Car: 85 T/A
its 01 ws6 rear with disc brakes what cable do i need. I did search but even with that i can not tell what cable i would need. thanks
Old Mar 1, 2008 | 01:19 PM
mcgarnicle's Avatar
Car: 1991 Z28 1LE
I used the stock cables that came with my rear end and used some rope clamps from home depot to shorten the passenger side one, worked great.
Old Mar 1, 2008 | 02:48 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
did you read the links?
https://www.thirdgen.org/forums/brak...-ebrake-2.html
Tru-Torque c94597/Bendix c1647. That will work but you'll have to dremel out the ends that slip on the caliper levers, and there will be 1/4-1/2 inch extra cable slack where it attaches to the ebrake handle's equalizer. You can attach clamps to it to take up some of the slack
1992rs/ss
Jan 31, 2025 05:10 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
1992rs/ss
16
Jan 28, 2016 09:58 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
THABADGUY
Brakes
Aug 11, 2015 03:43 AM
