Knocking Noise when In Gear
Old Mar 5, 2008 | 10:00 PM
bbq014's Avatar
Car: '88 IROC
Axle/Gears: 9", Locker, 4.10's
Hey guys,
When I'm in gear i get a knocking noise that gets faster with speed (not rpm).
When i'm rolling and i push the clutch in and leave it in gear it stops, also when i'm in neutral.
This is in all gears, at all speeds.
What could it be, a friend of mine said rear end, but thats relatively new.
But then again I got my rear from Chris Caprio who isn't exactly getting rave reviews.
Anyone have this problem or know whats up?
Tim
Old Mar 5, 2008 | 10:22 PM
Batass's Avatar
Car: 91 rs
Engine: Blow through 383, 10 psi, xr288hr
Transmission: Manual th350 ATI 3000
Axle/Gears: 3.50 9"
Re: Knocking Noise when In Gear
Definitely something in your trans, I'd drain the fluid and look for metal.
Old Mar 5, 2008 | 10:26 PM
402 GTA's Avatar
Car: 86 GTA
Engine: 402 cbb
Transmission: th350
Axle/Gears: 9" 3.50
Maybe throw-out bearing.
Old Mar 6, 2008 | 09:45 AM
bbq014's Avatar
Car: '88 IROC
yeah i was thinking either the throwout bearing or clutch fork or something...
going to take it to the shop today so hopefully it's nothing too major.
thanks guys,
Tim
Old Mar 7, 2008 | 03:12 AM
Pat Hall's Avatar
Sounds like broken or chipped teeth on the gears inside the trans to me. Only one gear has to have broken teeth for it to happen since no matter what gear you're in, all of them spin against the big cluster gear. I broke 2nd gear in my Muncie a few years ago, and it did the same thing your car is doing. I'd recommend not driving it until you figure out the problem. I got lucky and only had to replace 2nd gear since I took it straight home and parked it. If you keep driving it with a broken gear, it'll take out the cluster gear, which is expensive to replace.
Old Mar 7, 2008 | 06:31 PM
bbq014's Avatar
Car: '88 IROC
Well, my friend was right...
something in the center section of my rear is shot.
so i'm having the whole center section rebuilt with new gears at Action Performance in Bohemia, NY. i learned my lesson from buying from unreliable sources from the internet.
time to scrounge up some cash!
mission: trans delayed once again lol
Thanks guys
Old Mar 7, 2008 | 06:42 PM
Batass's Avatar
Car: 91 rs
Axle/Gears: 3.50 9"
Makes sense if its on the load side of a tooth. Turned it by hand and felt it?
GTAman
Jul 3, 2024 07:29 PM
IROCtometal
Sep 20, 2015 11:08 PM
IROCtometal
Sep 9, 2015 10:01 AM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
