Lakewood scattershield
Car: 1986 Camaro SC
Engine: 305 TPI Procharged D1SC
Transmission: Tremec TKO-600
Axle/Gears: Moser 12 Bolt 3.73 posi
can you use the OEM GM clutch fork with the 15020 scattershield? or do you need the laekwood fork?
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: Lakewood scattershield
you need the gm fork, specific for the thirdgen car, the lakewood fork is a different style.
Car: 1986 Camaro SC
cool i have that already with my 5 speed setup, bought me a tko-600 want to add the lakewood bellhousing, thanks guys!
Just a tip. I see in your sig that you have the Eibach Pro-Kit. While that kit doesn't drop your ride height a lot, I've read where guys with lowered 3rd gens have had ground clearance problems using the Lakewood scattershield. The bottom of the scattershield sits down lower than the stock bellhousing. More than likely, this probably occurs most often when using something like the Sportline springs, but just thought I'd point it out. The guy I bought my TKO from was using the Lakewood scattershield and he said it scraped the road a few times.
Car: 1984 Trans Am
Engine: broken 385sbc
Transmission: G-Force rebuilt T-5
Axle/Gears: Currie 9" Ford 4.30:1
use the clutch fork made for our cars..
Pat Hall, i used to have sportlines with my lakewood and had NO problems at all.. unless you are doing some rock climbing in a third gen, you shouldnt have a problem.. i do believe the crossmember still sits lower than the bellhousing..
Car: 1986 Camaro SC
i'd rather keep my legs then worry about scraping
Car: 86 Trans Am
i actually scraped a couple times with mine with sportlines, but this was being a little too "spirited" on backroads with a high crown.
1992rs/ss
Jan 31, 2025 05:10 PM
Hotrodboba400
Dec 10, 2019 07:07 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
