B&M 30299 Install Question
Old Mar 7, 2008 | 11:57 PM
Sooo_slow's Avatar
Car: 82 Z28
Engine: 327
Transmission: TH350
Finally was able to track down the 30299. Just a few questions on those that have swapped for the th350. Do I have to take the tail section off or take the drive shaft out to install it? Crossmember have to come off?
Just wondering estimated time on install?
Thanks in advance.
Old Mar 8, 2008 | 09:06 AM
87zjeff's Avatar
Axle/Gears: '01 3.42 10 bolt
Re: B&M 30299 Install Question
30229 is a complete rebuild kit so...yes, the transmission has to come apart.
Old Mar 8, 2008 | 02:19 PM
Sooo_slow's Avatar
Car: 82 Z28
Engine: 327
Transmission: TH350
The 30299 is the swap kit, consisting of a bracket to mount the torque arm. It's not a tranny rebuild kit. And from a picture I found, you dont have to take the tail section off or driveshaft.
The only thing I'm now uncertain of is actually installing the bushing on the bracket. Any help on that?
Old Mar 8, 2008 | 02:39 PM
87zjeff's Avatar
I looked at the part number the wrong way.
depends on which th350 you have. if you use the short th350, then you will need a longer driveshaft.
I would also think you needed the early torque arm for that kit because the th350 case is shorter than the 700r4 meaning that mount will be further forward unless the mount is made to accomodate that part.
the bushing bracket should mount with te hardware from the kit as opposed to using the factory bolts.
Old Mar 8, 2008 | 03:42 PM
Sooo_slow's Avatar
Car: 82 Z28
Engine: 327
Transmission: TH350
I bought the car, and it already had the tranny installed as well as the driveshaft. So really my only concern is mounting the bushing to the bracket.
There is essentially 2 pieces from the factory mount. An inner and an outer. Im unsure of what parts from the factory mount to use. All I really need is a picture of it installed.
Old Oct 18, 2009 | 04:46 PM
flamingitup's Avatar
I dont the swap to the 350 and used the 30299 from B&M and it worked great. You dont have to take anything apart it installs using 3 of the outer bolts on the tail shaft of the transmission. Getting the speedometer cable screwed in thru the bracket can be a pain but it was a easy install.
Old Oct 18, 2009 | 07:19 PM
Sooo_slow's Avatar
Car: 82 Z28
Engine: 327
Transmission: TH350
Wow, such an old topic. But yes it was extremely easy to install, and for the speedo cable issue, I just slid the bracket over the speedo cable, tightened the cable, then bolted the bracket on. The bushing mount was a bit of trouble, but I just reamed out the stock mounting holes and it fit like a glove.
Old Nov 24, 2011 | 01:32 PM
Tx89RS's Avatar
do you guys have pics or instructions of this install?? my daughter decided to draw and tear up my instructions lol
Old Jun 24, 2012 | 12:34 PM
estesformula87's Avatar
Car: 90 camaro rs
Engine: 409 sbc
Transmission: th350
why will no one ever show this installed it could be a sticky if some one did has been asked a million times and no one has show how these hurst and b&m kits go in wow!! i have the same probplem i think i might be getting some where with it righ now but i dont know for sure lmao
Old Jun 26, 2012 | 08:17 PM
krisner89's Avatar
Car: 87 camaro
Transmission: th350
Axle/Gears: auburn 4.10
Hopefully these can help those wondering what it looks like after install. The bushing in these pics have a modified energy suspension bushing (had to do some cutting on the bushing with a band saw to make it fit this bracket). It came with the edelbrock torque arm that is in the pics.
NOTE: The outer bracket that holds the bushing and torque arm to the B&M bracket is the one that was originally on your car. you re-use it(for the guy who has no instructions)
Attached Thumbnails B&M 30299 Install Question-brackets.jpg   B&M 30299 Install Question-bracket.jpg   B&M 30299 Install Question-brack.jpg
Old Jun 26, 2012 | 08:29 PM
krisner89's Avatar
Car: 87 camaro
Transmission: th350
Here is the old bushing I had on the b&m bracket when i had the stock torque arm in. The bigger one is a little bent cause i had to grind off the rivets and pry it off so i could put the energy suspension bushing in.
Attached Thumbnails B&M 30299 Install Question-bus.jpg   B&M 30299 Install Question-bush.jpg   B&M 30299 Install Question-bushing.jpg
Old Jun 28, 2012 | 03:37 PM
Car: 90 camaro rs
Engine: 409 sbc
Transmission: th350
hey looks like i guessed close to right go me lol thanks very much wish i had these before would of been a very big help
Old Dec 24, 2016 | 05:13 AM
brooksy's Avatar
Car: 87 Iroc z
Engine: 67-76 350 carb
Transmission: 700 Auto
Where can I get a B&M 30299 kit.
Cheers brooksy
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
ASE doc
Alternative Port EFI Intakes
Aug 25, 2015 09:14 AM
redmaroz
Aug 16, 2015 11:40 PM
