Vibration In Low Gear 700R4
Car: 92 Firebird Convertible
Engine: 355
Transmission: PerformaBuilt 700R-4
Axle/Gears: 373
I am finding a bad vibration when I am in drive or lower gears. The higher the RPM the worse it gets. If I shift it into overdrive the problem seems to go away. Am I having problems with the overrun clutch? I recently put a 2500 stall converter in it if matters. If anyone has any information I would greatly appreciate some input.
Car: 1985 chevy camaro IROC-Z
Engine: 5.7 litre 350 4 bolt main
Transmission: 700r w/B&M shift kit
Axle/Gears: 10 bolt w/3:42 gears
Re: Vibration In Low Gear 700R4
im not an expert but id check the tranny mount,i dont think it has anything to do with the stall converter but its a possibility
