t56 throw out bearing and hydraulics
Old Mar 23, 2008 | 12:20 AM
jake wagoner's Avatar
i have looked alot for a throw out bearing for my t56 all i can find are the hydraulic ones that cost around $150, the regular ones comes in clutch kits but im just gona use the clutch and flywheel that i got with my transmission. my question is; is there someplace i can find a throw out bearing or are the hydrualic ones better for some reason that i dont know, since im converting from a t5 im gona need a new master/slave cylinder anyways so would somebody mind telling me what my options are and what the benefits and downsides are. thanks alot for any help
Old Mar 23, 2008 | 09:43 AM
Re: t56 throw out bearing and hydrualics
What year of T-56 do you have? Or, what motor was it behind?
Old Mar 23, 2008 | 02:49 PM
my car is an 86 trans am had 305 with 5 speed. im putting a 6 speed in it out of a 94 camaro with an lt-1 out of a 95 camaro that had an auto behind it
Old Mar 23, 2008 | 06:59 PM
The throwout cannot be replaced separately in the LT1 system. It's part of the clutch. Made into it.
The hydraulic ones are for the LS1 setup. Won't work in the LT1 one.
Old Mar 23, 2008 | 10:50 PM
im sory for not understanding competely. are you saying that i cant buy a throw out bearing that they only come in clutch kits or are you saying they are built into the clutch because when i look at it the fork looks like it would hold a regular bearing to ride up against the fingers of the pressure plate where there is also no bearing i dont understand how it can work with just the fork against the pressure plate
Old Mar 24, 2008 | 07:42 AM
The LT1 T-56 clutch fork pulls on the throwout bearing, rather than pushing like most every other clutch. The bearing is part of the clutch as a result, not a separate piece.
http://store.summitracing.com/largei...y-85-125_w.jpg
Note how it's made into the clutch.
Old Mar 24, 2008 | 09:48 PM
Stevo's Avatar
Car: Pair of 92 Z28s
Thats why i was so confused switching from a T56 back to a T5 setup.
Old Mar 25, 2008 | 08:25 AM
Re: t56 throw out bearing and hydraulics
huh... thats interesting, i see what you are saying now and now im a lil disapointed that my clutch dosnt have that made into it anymore, i can see the wear from where it use to be. i guess ill just have to order a new clutch and ill have a few more spare parts in the garage. thanks for the help
Old Mar 25, 2008 | 08:34 AM
And who DOESN'T need that, right?
Actually, it's just garbage, if it's used; and especially if the bearing is gone. You can't use it for anything anyway, as you're finding now. Not alot of sense in hanging onto it, it's not good for anything.
88SS6SPEED
Nov 11, 2015 07:05 AM
topteam54
Oct 6, 2015 12:21 AM
el_muerte
Sep 16, 2015 12:01 AM
mygta87
Sep 14, 2015 10:36 PM
Numbah-1
Sep 12, 2015 08:57 PM
