Trans problem or something else??
Old Mar 25, 2008 | 10:41 PM
1montess's Avatar
I recently purchased a used crate 305 TBI and 700r4 for my '91 RS. I got it installed and running last weekend. When I rev the engine with it in park it hesitates and doesn't have the quick snap in the throttle that I am use to with a carbureted engine. When I put the car in gear it will roll fine at idle, but when I hit the gas the engine will hesitate and sputter, and even die if I push the gas too fast. Any ideas? I'm having trouble with the VSS and getting my speedo to work. I was told that the VSS could cause to torque converter lock up to malfunction. I also believe that there may be a problem with the fuel system. I have replaced the fuel filter, but that's it. Trans or fuel problem? Thanks!
Old Mar 25, 2008 | 10:56 PM
Uncle Skeletor's Avatar
Car: 1991 Camaro RS
Engine: 350, Edelbrock Pro Flo efi
Axle/Gears: 4.10 on a torsen diff
Re: Trans problem or something else??
Really doesn't sound like your converter is locking. You could unplug the lockup connector on the side of the tranny to eliminate it as a potential problem, but more than likely it's going to be an electronic or fuel problem.
Old Mar 25, 2008 | 11:03 PM
Any ideas?
Tuning.... what's your fuel pressure?
What kind of trouble? What does it do?
Old Mar 26, 2008 | 08:59 PM
1montess's Avatar
I've talked to you before sofakingdom about my trans and a prob with the VSS. Since you advised me I've purchased another complete engine and trans. I tried splicing in the wires that teh previous owner had cut out of the harness for the TCC and VSS and noticed that there are TWO purple wires. I don't know which goes where! I've tried the wires both ways and my speedo refuses to work. I searched old threads and found a diagnostic flow chart for checking the VSS and buffer. I'll do that this weekend. If you guys have any other pointers I'll gladly take them.
*Also*
What should the fuel pressure be at the injectors at idle? At part throttle?
84z96L31vortec
Aug 20, 2017 12:16 AM
TheJoeY88
Dec 31, 2016 07:30 PM
gta power
Aug 13, 2015 06:15 AM
84z96L31vortec
Aug 10, 2015 08:27 PM
