i think i messed up
Car: 1982
Transmission: 350
i think i messed up
i have been looking for a posi carrier for my 82 camaro and on ebay i finally found one so i got really excited and bought it not realizing that its for a 9 bolt rear end..... i have a ten bolt..... i just saw that it had the splines i needed (26) and it was a good working posi carrier out of a 84 camaro.... did i just waste my money????
john
this is the discription off ebay...
Up for auction is a factory 9 bolt Borg Warner limited slip differential carrier. Parted from a 1984 Camaro Z28 with a 5.0L engine. The diff seemed to be working fine before I removed it. This one had 26 spline axles and a 3.27 gear ratio. This unit will fit all the above listed vehicles as long as you have a 9 bolt differential cover. Can be used with many different ratio gear sets. I would recommend checking with various gear set vendors to see what is currently available. The bearings, bearing cups and bearing spacers are included. The bearings seem to be in good shape, but I would probably replace them anyway. The bearings and cups are marked for correct installation if you decide to use them. The ring gear bolts are included. Everything you need for an easy installation! If your shipping address is not in the lower 48 States, you MUST email me before bidding or your bid will be cancelled. Thanks for looking and have a good day!
john
Car: 88IROC, 91Z28 + parts cars
Engine: 355, 408
Axle/Gears: 3.42 LS1, 9" w/ 4.56 and spool
Re: i think i messed up
I know the ring gear on the 9 bolt is 7.75 and the other difs are 7.625 or 7.5 and if i'm remembering correctly the 9 bolt also has different posi unit. However if you would like an axle to match your posi i have one that is fully POR15ed that I would be happy to sell you
9-bolts don't have 26-spline axles.
9-bolts weren't available in 84.
Therefore, if both of those things are true, it's not a 9-bolt part.
Post a pic. Show what's inside the little window. Hopefully it's not an Eaton Gov-Lock.
so am i screwed?
I guess you'll find out when it shows up.
Have your hardened steel jock strap ready, just in case. Thread Starter
Car: 1982
Transmission: 350
well thanks for the info sofakingdom i dont have any pics yet but when i get the carrier ill put some up... when i get the carrier how will i know if itll fit or do i just take the diff apart and try it? i dont know if this helps but i do have a set of 4:10 gears for the car thats sitting in my garage can i match anything up with those?
Car: 1982
Transmission: 350
well guys the guy that listed the carrier is really cool i told him its not the right part and he just hants $10 bux to relist it... wheew dodged a bullet lol thanks for the info guys
john
john
Car: 1982
Transmission: 350
i just wasnt sure what it was he told me again it was for a 9 bolt he said that he pulled it out of a 9 bolt rear end so i just asked if i could pay to have it put back on ebay and he said that it was find i just didnt wanna take a chance of wasting 100 bux
