linkage probrem
Old Mar 29, 2008 | 12:28 AM
rs_racer_20's Avatar
Car: 92 RS
Engine: 3.1 (191) V-6
Transmission: 700-R4
Axle/Gears: pos track
linkage probrem
Well it never happened before, one yesterday wen i got off work turn my car on and was going to put it on drive wen the shift handle was loose and i dint know what it was until i took the hole middle compartment off and saw that the cable linkage was connected to the handle, so i looked at the next thing, under the car and fount out that that the shift linkage disconnected from the tranny. So now every time i put the car on park the shift linkage comes off and i have to get under the car to put it back in place to be able to drive, thats getting anoying to do all the time so can i get help with my problem is there a kinda of clip to hold the shift linkage? or something cuz i think my car dont have the clip on,
Old Mar 29, 2008 | 12:30 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: linkage probrem
isnt it held together with a bolt?
Old Mar 29, 2008 | 07:40 PM
Car: 92 RS
Re: linkage probrem
No is like clip in but it looks like it has to be put in but it comes off wen im trying to shift
Old Mar 30, 2008 | 11:12 AM
billymac49's Avatar
Car: 88 IROC
Engine: 5.0 tpi
Transmission: 700 r4
Re: linkage probrem
doesn't sound like a stock setup. the only ones i've seen are held together with a bolt, or pops on with a ball and socket.
Old Mar 30, 2008 | 11:27 AM
billymac49's Avatar
Car: 88 IROC
Engine: 5.0 tpi
Re: linkage probrem
oh yeh my bad. there may be a cotter pin that holds the cable on to that shifter pin.
Old Mar 31, 2008 | 11:12 AM
Car: 92 RS
Re: linkage probrem
It does look like its held by a bolt but it has this plastic trim that is part of the linkage and i think it has to clip in the the metal thing sticking out but for some reason it dont clip, it just stays on until it come off again,were in the point im getting tired of going under the car to clip it on again. it sucks!!!!!
Old Mar 31, 2008 | 06:23 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Re: linkage probrem
got a pic?
Old Mar 31, 2008 | 09:11 PM
dirtywhiteZ28's Avatar
Car: 84' Z28-White/T-Tops
Engine: H code LG4 305
Transmission: TH700R4
Axle/Gears: Stock 3.23
Re: linkage probrem
There's a plastic button that slips over the pin, when you put the cable on the plastic part it should snap. These things wear out over time. Fortunatly they are readily available at the dealerships for about $3 dollars, a new one will be very hard to clip, be patient you won't have to replace it for a looong time.
Old Mar 31, 2008 | 09:20 PM
Re: linkage probrem
I see your here in Houston. If the nearest dealer to you doesn't have it in stock then try West Point Buick 281-493-2000 they have the second largest parts wharehouse in Texas for all GM parts.
Old Apr 1, 2008 | 12:35 AM
Car: 92 RS
Re: linkage probrem
Thanks alot bro, I thout that i had to replace the hole shift linkage Ill give them a call tomorrow
budowski
Carburetors
Oct 2, 2015 10:16 AM
mfp189
Sep 27, 2015 09:25 AM
IROCNParts
Sep 24, 2015 10:50 AM
Magman
Sep 14, 2015 01:30 AM
tonys91rs
Sep 2, 2015 07:07 PM
