torque/stall converter question
Old Mar 30, 2008 | 03:37 PM
davep_96's Avatar
Car: 1987 Trans Am GTA
Engine: 355
Transmission: TH-700r4
I did some searching and some research and i'm still a bit confused. I am building up my 350 and i am confused about this whole torque/stall converter thing. First, do i need to purchase one? I am getting a new cam, headers, possibly heads, and carb. I am trying to make a street car used for some weekend drag racing and also a daily driver. I have heard of people getting a new torque converter but im not sure if i need one. Second, exactly what is "stall" and when do people want/need a higher stall. My auto trans already has a shift kit. Is this good enough?
Old Mar 30, 2008 | 04:16 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: torque/stall converter question
What are the cam specs you intend to use? That can help determine a stall speed recommendation.
Read these
http://www.hardtail.com/techtips/torqueconverters.html
http://www.hardtail.com/techtips/sel...converter.html
Old Mar 31, 2008 | 05:06 PM
davep_96's Avatar
Engine: 355
the cam is a comp cams xtreme energy, .477/.480 lift, 268/280 duration, rmp range 1600-5800. i havent bought anything yet so i could always go with a different part if i needed to. also forgot to mention i am getting a new intake too.
Old Mar 31, 2008 | 05:32 PM
leeperryracing's Avatar
Car: cleanest '86 sport coupe around!!
Engine: 355ci twin 66mm turbos on e85
Transmission: built rmvb th400 w/ t-brake
I would go with a 2600 stall, 2800 would be the cut off for that cam. What kind of heads/intake are you going to use? if you have "decent" heads and intake along with around 9:5:1-10:1 CR, you can run a much better cam with a little more stall and make damn good power....but that all depends on you and what your goals are.
Old Mar 31, 2008 | 09:47 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Comp Cams suggests a converter with 2000+ stall is required for that cam. I would recommend a minimum of 2100-2200 stall with 2500 being about the most you should use. That puts the stall speed roughly 500 rpm into the cam's powerband where it will do the most good.
Don't forget that any converter higher than stock stall speeds also needs an aftermarket tranny cooler to help remove the extra heat generated by the higher stall.
1992 Trans Am
May 10, 2023 07:19 PM
69 Six Pack
Oct 5, 2015 07:51 PM
Fronzizzle
Aug 19, 2015 01:36 PM
redmaroz
Aug 16, 2015 11:40 PM
gta power
Aug 13, 2015 06:15 AM
