body twist?
Old Mar 30, 2008 | 10:59 PM
vasquezmrysvll's Avatar
Car: 1985 California Iroc
Engine: HSR ZZ4 0411 swapped
Axle/Gears: 3.23 posi
body twist?
since I converted from a 700r4 to a t10 my doors seem to be sagging or somthing? do i need sfc's? the car is a 85 iroc w/ t-tops. thanks
Old Mar 30, 2008 | 11:01 PM
Rva's Avatar
Rva
Car: 1984 z28 camaro
Re: body twist?
Pictures?
Old Mar 30, 2008 | 11:35 PM
Re: body twist?
what do you need pics of?
Old Mar 31, 2008 | 02:29 AM
mcgarnicle's Avatar
Car: 1991 Z28 1LE
Re: body twist?
the trans swap shouldn't have anything to do with your doors sagging.
Doors sagging is a very common problem on our 3rd gens, new "joints" sorry I can't believe I can't remember the name (early) they have greasable ones that I've heard are the best ones to get to solve the sag in the doors.
Old Mar 31, 2008 | 05:57 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: body twist?
mcgarnicle, you silly rabbit! Door hinge. Here're several kits from TDS:
http://www.top-downsolutions.com/ind...63a0f53a164d91
JamesC
Old Mar 31, 2008 | 08:58 AM
mcgarnicle's Avatar
Car: 1991 Z28 1LE
Re: body twist?
JamesC
Yes, thank you JamesC. I remembered when I was on my way out the door for work, can't believe I couldn't remember door hinge
Old Mar 31, 2008 | 09:55 AM
Re: body twist?
before the manual the doors were fine. after driving with the manual, the doors hang up? its not too bad, but there is a difference.
Old Mar 31, 2008 | 12:36 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Re: body twist?
The tranny (logically) shouldn't have made a difference. I'd guess the doors are just a bit tweaked. You can get Lons tool to "bend" the door up higher, but it's better to get new hinges, then bend them if need be.
Andyz28 makes the kit as well I think, Lon might be selling Andy's kit IIRC.
Old Mar 31, 2008 | 06:27 PM
titan's Avatar
Car: 1990 Camaro RS
Engine: L03 305 TBI
Re: body twist?
Did you use jacks and jackstands to do the swap? How long was it up in the air if it was on stands. I would think these things could have affected the doors, if it were lifted wrong, or sat in the air for quite some time.
Old Mar 31, 2008 | 06:38 PM
Re: body twist?
it was lifted and supported properly.
Hotrodboba400
Dec 10, 2019 07:07 PM
1Aauto
Sponsored Vendors
Jan 15, 2016 06:26 AM
Silver Spear
South East Region
18
Dec 4, 2015 09:59 PM
1Aauto
Sponsored Vendors
Sep 10, 2015 02:02 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
