strange enginerring
Car: 88 pontiac trans am,79 z28
Engine: 350,350
Transmission: 700r4,th350
strange enginerring
what is the best setup for a 88 trans am from stange.i was looking at there catalog and came across a drag racing rear for the f-body,but they didn't list what gears were in it.anyone have one in there car.this will be a mostly drag car and street only occasionaly(gas prices being the main drive behind this).also,does anyone make traction bars for these cars.i only ash because i haven't ever really seen any under a thirdgen.
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: strange enginerring
When you order a differential from companies such as Strange, you custom order it to your specifications.
A 12 bolt usually has 30 spline axles although bigger axles can be ordered. 30 spline axles are more than enough for the typical car. Gear ratio depends what you need. Someone may want one with mild 3.50 gears for the street. A high reving, full drag only car may want 5.13 gears. A street car will want a posi while a drag only car will want a spool.
After the complete list of items is known, a price for the complete diff can be figured out. You can estimate around $2500 complete with brakes. You can also buy a bare housing with axles and install your own gears and posi.
Third gens don't use "traction bars". The coil spring, torque arm suspension doesn't need traction bars although there are improvements to be made to the factory suspension.
Engine: 350,350
$2500 is what i was looking to spend so that's cool.i appreciate the info.i was thinking with going with 4.56 gears,what do you think.also what is the widest tire you can get to fit.looking to get some dragslicks back there,and i'm trying to get the best time out of the setup without backhalfing the car.mid 11 should be doable with 550-600 hp with good hook,right?
Car: 87 IROC L98
Gear selection depends on a lot of things.
Camshaft profile, engine operating range, transmission choice, tire height.
Engine: 350,350
well, the cam in the motor going in is pretty stout.when i purchase the rear,i'll be getting a full roller cam,i' trying to squeze out 600 hp.the trans is a built 700r4 from monstertransmissions.com.the tire selection in the back,i don't know yet.i'll be looking to get some slicks but i don't know how big and wide i can go in stock location.i want to hold back on any tubbing of the car.just for the time being.
red90IROCls1
Aug 25, 2015 06:56 AM
