why me
Old Apr 6, 2008 | 01:03 PM
billybob6110's Avatar
Car: 1984 chevy camaro
Engine: 355
Transmission: turbo 350 2800 stall
Axle/Gears: 3:73 detroit locker posi
why me
ok i gota 305 700r4 tranny and its having an issue. when i stomp the gas itll shift great threw 1&2 but as it gets ready to go into 3rd it wont shift unless i let off the gas and stomp it again. wtf is going on? im at wits end with it. any help is appreciated
Old Jul 11, 2009 | 09:08 PM
Engine: 355
Re: why me
anybody got any ideaS?
Old Jul 11, 2009 | 09:15 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: why me
is the TV cable set properly?
Old Jul 11, 2009 | 09:26 PM
Engine: 355
Re: why me
as far as i know, im not sure how to tell if its correct
Old Jul 12, 2009 | 12:35 PM
transtalker's Avatar
Car: 95 Suburban K1500
Engine: 355 TBI,heads,cam,flowmaster exhaus
Transmission: 4L60E custom rebuild, mod shift kit
Axle/Gears: 3.08 front and rear
Re: why me
to check the tv cable you pull your throttle wide open then take your finger and see if you can pull the cable any further at wide open throttle you should not be able to pull it any further if you can pull it out further you will need to push the button on the cable down then move it in or out depending if it is too tight or to loose
Old Jul 12, 2009 | 07:42 PM
Engine: 355
Re: why me
if its to loose or to tight what will it do?
Old Jul 13, 2009 | 02:27 PM
TAGTASCOTTY's Avatar
Engine: 408ci Stroker, 520hp 515Ft.Lbs.
Transmission: Outlaw 700r4
Axle/Gears: 3:73
Re: why me
It will smoke your 3/4 clutch pack if it is loose, You want the cable to be tight.
Old Jul 14, 2009 | 07:01 PM
Re: why me
there is a bracket that the cable runs thru from your transmission to your carburator or throttle body at the bracket there is a button on the cable push it down;on the other side of the bracket you will see a plastic sleve that sticks out over the cable this is your adjustment.if your cable is too loose you push the plastic sleve back towards fire wall , if it is to tight you move the sleve out towards front of car
