9" your opinions?
Old Apr 10, 2008 | 05:16 PM
mbolte's Avatar
Car: 1987 Camaro
Engine: 350 dart ies comp cam intake carb
Transmission: 700 r4, shift kit, 2400 stall
Axle/Gears: 10 bolt stock
9" your opinions?
well I think I know what I wanna do for a good rear...
I found the 9" housing with axles from spohn:
http://www.spohn.net/?action=product&pid=1533
Im thinking buy that, then find a used pumpkin to put in it for cheap.
Any ideas and also what else would i need to do this...and will my factory brakes work?
-matt
Old Apr 10, 2008 | 05:35 PM
WIll36's Avatar
Car: 88IROC, 91Z28 + parts cars
Engine: 355, 408
Axle/Gears: 3.42 LS1, 9" w/ 4.56 and spool
Re: 9" your opinions?
its says right under the brake option tab that the factory drum brakes won't work. Also don't forget to get the correct axles if you decide to build the assembly yourself
Old Apr 11, 2008 | 01:06 AM
jstoltz's Avatar
Car: 1987 Iroc-z Convertible
go either with the moser from Spohn with axles or there is this place from Ebay. I really haven't heard much good or bad about them but they look pretty good and I kinda like the torque arm mount better. but you would have to get an adapter plate for the brakes unless they could have the right pattern put on instead of the big bearing ford ends? not sure cost is about the same because of this.
http://cgi.ebay.com/ebaymotors/9-For...spagenameZWDVW
that one comes with the correct length moser axles. either way get the housing and axles as a package so you know they are correct verify anyway though. and get a nodular center section. as far as brakes it just depends on what size tire you are using but I would go with the ls1 brakes on the rear if your not running a 16" tire go with lt1 I am pretty sure they will fit in the rear with 15's
Old Apr 11, 2008 | 04:19 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
mosers is better than the ebay place, they use remanned center housings and only 1 style housing end. Just get the moser piece, you will be happy you did.
Old Apr 11, 2008 | 06:35 PM
jstoltz's Avatar
that's what I was kinda thinking too just because of the ends, the reman center section really isn't a big deal. with either one the main thing to worry about is the welds on everything. I would go with the moser housing though so that way ls1 or lt1 brakes are a direct bolt on. the ebay one is setup for explorer brakes definitely not the best choice.
Old Apr 12, 2008 | 12:15 AM
mbolte's Avatar
Car: 1987 Camaro
ok good to hear...i will be running 15" wheels so brakes im still a little confused about...i got stock drums on it now...would it be easier to do third gen disc brakes or go with the lt1 ones?
Old Apr 12, 2008 | 06:45 AM
greezemonkey's Avatar
Car: A Portly 85 Z28
Engine: 4.530 X 4.250 BBC
Transmission: under rated for this application
Axle/Gears: also under rated
is it me or is that thing going to hit the floor /tunnel unless you have it 4x4`d !!??
Old Apr 12, 2008 | 10:48 AM
jstoltz's Avatar
that's kinda what I thought but they said it doesn't but then again they are selling them. looks pretty beefy though. I would do the lt1 brakes or swap some third gen disc but the lt1 stuff is easy to find.
Old Apr 12, 2008 | 11:27 AM
//<86TA>\\'s Avatar
Car: 86 Trans Am
that torque arm bracket on the ebay one MUST eat the floor. the moser on will sometimes require some hammering and its much lower than that
Old Apr 14, 2008 | 11:44 AM
Tony89GTA's Avatar
Car: 89 GTA
Engine: 5.7L Supercharged
Axle/Gears: Moser 9" 3.70
Yeah I can't see that thing working myself.
Pac J
May 17, 2020 10:44 AM
LiquidBlue
Wheels and Tires
32
Dec 10, 2019 04:06 PM
cheesehomer
Dec 31, 2015 08:48 AM
skinny z
Oct 5, 2015 06:23 PM
Jlanz55
Sep 29, 2015 08:55 AM
