Is this diff worth installing?
Old Apr 11, 2008 | 04:42 AM
pezza's Avatar
Hi all,
I wondered if anyone could advise me on whether installing the following diff is worth the potential pain or not.
I got hold of the following items shipped to the UK for just over 200 dollars, and I searched for some model numbers I am not sure about installing.
http://flickr.com/photos/7457194@N03...n/photostream/
The unit is exactly the same (including case id) as this one:
http://toronto.kijiji.ca/c-cars-vehi...QAdIdZ33800073
This topic from 2003 has made me think otherwise https://www.thirdgen.org/forums/tran...tify-posi.html
Is anyone running with this diff without problems. (I think Ed was using this diff back then)
If I needed to upgrade would a 7.5 28 spline and a diff from a 4th gen setup be good for say 450hp?
Thanks guys
Derek
Old Apr 11, 2008 | 02:25 PM
Randy82WS7's Avatar
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
Re: Is this diff worth installing?
Derek howdy there
i got your PM and replied with one
that one on kijji is junk its a gov-lok or better known as grenade-lok
the governor unit thingy mounted on it is the dead giveaway of this junk unit
its not even worth 20 let alone 200
run away fast,
the other one i cant tell what it is, i cant see the internals
the gov-lok was the most common limited slip unit out there in these later years, there was a cone type also but was not rebuildable
you need an auburn or an eaton clutch type posi unit
these cost 3-400 dollars
a better way is to find a complete posi rear from one of these cars
if you try to piece a rear together by trying to find and install a posi you will need special tools and knowledge to set it up properly so it wont ruin itself
these good/better units cost good money
a while back you could get left over factory later model 7.5" zexel units for 99 dollars but they ran out of them before i could pick up a few of them
good luck
Old Apr 11, 2008 | 02:51 PM
Randy82WS7's Avatar
Engine: 4.3L Z TBI
heres a couple different posi rears you would be lots better off putting under your car and are good prices:
narrow this one a bit, good street ratio already @ 3.50 or 3.55:
http://toronto.kijiji.ca/c-cars-vehi...QAdIdZ45591352
3.08 but is posi and no narrowing needed probably:
http://toronto.kijiji.ca/c-cars-vehi...QAdIdZ44584568
good luck!
Old Apr 14, 2008 | 03:45 AM
pezza's Avatar
Thanks Randy,
I feared this would be the case as soon as I saw it..I wish I asked for some pix...
I am based in the UK which often means trying to get hold of complete rear ends can be difficult. Breaking / salvaging camaros/chevs are not too easy to come by.
I would have liked to have gone up to a larger axle but shipping a whole rear end to the UK would be insane. so I may have to stick to 7.5 but maybe I can ugrade to 28 spline shafts / posi instead..
I did consider the detriot truetrac too. they were 350+ shipping.. I may have a search on here to see if anyone else has experience of these units.
Thanks again
Derek
1992rs/ss
Jan 31, 2025 05:10 PM
BewleyBizzIROC
Feb 3, 2020 09:52 AM
1992rs/ss
16
Jan 28, 2016 09:58 PM
Adamki2000
Brakes
24
Dec 20, 2015 10:40 PM
draco
Oct 4, 2015 09:25 PM
