NEED HELP!!! 700r4 wont shift into 2nd,3rd 4th!!!
I was on my way home from a local car show, and decided to floor it since there's an open highway dead ahead. It shifts great all the way up till 4th at around 3500 rpms, and then I come slowly to a stop. When I accelerate at a regular rate again, (in OD) it keeps turning rpms' like there's nothing left but 1st! It went all the way to 4000 without shifing up! I have absolutely no idea what is causing this problem. Any help is greatly appreciated. ( Current tranny mods are: 500 boost valve, 26K stall, shift kit, kevlar clutches and aluminum driveshaft)
Thanks for all input,
Will
Will
Re: NEED HELP!!! 700r4 wont shift into 2nd,3rd 4th!!!
Anybody? Please help. This is very frustrating, and I hope the soloution can be done myself, as I don't have the funds to get a shop to fix this. Thanks for your time.
Will
Will
The governor gear is most likely stripped or broken. Solution, pull governor and replace the gear, make sure you put a O-ring on the governor cover on the install. Hit the outside of the governor cover only when putting it back in.
Thanks a lot ProBuiltAutomaticss! I'll try to get her jacked up and check the governor gear. If I still haven't solved this, I'll PM you back. Thanks once again. Help is always appreciated.
Will
Thanks a lot ProBuiltAutomatics! I'll try to get her jacked up and check the governor gear. If I still haven't solved this, I'll PM you back. Thanks once again. Help is always appreciated.
Will
Will
Will
someone972
Aug 30, 2015 12:52 AM
Thornburg
Aug 25, 2015 01:46 AM
dhonda200
Aug 11, 2015 11:50 PM
